Roomba won't leave the dock
Postby Roombanova » November 15th, 2018, 3:34 pm
Hi, my Roomba 800 won't leave the dock anymore. It won't do it on schedule nor when I press the clean button. If I take it off the dock it will work perfectly and dock itself as well. I suspected a battery issue and changed the battery but this didn't help. I've also reset the Roomba a few times and moved the dock to different places.
I haven't seen anyone having this problem even after some serious searching. Any ideas?
Roombanova
Re: Roomba won't leave the dock
Postby vic7767 » November 15th, 2018, 4:45 pm
Have you observed it performing any backing moves at all?
Postby Roombanova » November 15th, 2018, 5:23 pm
What do you mean ? When I take it off the dock it will work perfectly and perform a complete cleanning cycle and dock itself after 10/20 min.
Roombanova
Postby NoJimForHome » November 15th, 2018, 5:25 pm
I think Vic's question was "do you ever see Roomba move backwards?" Like, if it bumps into something, will it back up?
Now I also have a question... your Roomba only cleans for 10-20 minutes before returning to the dock?
NoJimForHome
Postby Roombanova » November 15th, 2018, 8:30 pm
Yes it's move backward when it bumps into something. There is nothing diferent compared prior this strange issue.
I said 10/20 min, but it's actualy 30+min. It's just when it's docked roomba is totally stuck. It won't do it on schedule nor when I press the clean button. Charging is ok, battery is OK, move is OK and return to dock too.
There is a sort of "lock" feature that I never heard of ?
Roombanova
Postby vic7767 » November 15th, 2018, 9:01 pm
There may be mechanical interference preventing the Roomba from leaving the base. Check the charging contacts on both the underside of the Roomba and the top of the homebase.
Postby TechGuy » November 16th, 2018, 9:49 am
Roomba is thinking that it is charging using the side jack. This is the reason why Roomba Roomba can't be started on schedule or using clean button.
Postby Roombanova » November 16th, 2018, 10:29 am
First, I appreciate your help :D
TechGuy wrote:Roomba is thinking that it is charging using the side jack. This is the reason why Roomba Roomba can't be started on schedule or using clean button.
Hum.. intresting ! But my roomba does not have side jack charging plug. Maybe a defect component on motherboard who "simulate" this behavior ?
vic7767 wrote:There may be mechanical interference preventing the Roomba from leaving the base. Check the charging contacts on both the underside of the Roomba and the top of the homebase.
Charging contacts seem to be good.
Roombanova
Postby TechGuy » November 18th, 2018, 1:05 pm
Roombanova wrote:First, I appreciate your help :D
It does not make any sense. I cannot think of anything which will prevent Roomba from starting a mission.
If it is thinking charging from the side jack, it will not charge on home base. This is normal.
But it is charging on home base and don't want to start while it is on home base. This is a new strange behavior.
Postby vic7767 » November 18th, 2018, 2:39 pm
It may be time to perform the Built in tests and pay particular attention to the RCON sensor on top of the bumper. Possibly a false IR emitter signal is triggering the RCON sensor.
Users browsing this forum: drunkpenguin, im1kissfan, Ionic, jdong, johnnyh, leonicholson, Miles267 and 270 guests
