Roomba won't leave the dock
- vic7767
- Robot Master
- Robot Groupie
I said 10/20 min, but it's actualy 30+min. It's just when it's docked roomba is totally stuck. It won't do it on schedule nor when I press the clean button. Charging is ok, battery is OK, move is OK and return to dock too.your Roomba only cleans for 10-20 minutes before returning to the dock?
- vic7767
- Robot Master
First, I appreciate your help
Hum.. intresting ! But my roomba does not have side jack charging plug. Maybe a defect component on motherboard who "simulate" this behavior ?TechGuy wrote:Roomba is thinking that it is charging using the side jack. This is the reason why Roomba Roomba can't be started on schedule or using clean button.
Charging contacts seem to be good.vic7767 wrote:There may be mechanical interference preventing the Roomba from leaving the base. Check the charging contacts on both the underside of the Roomba and the top of the homebase.
It does not make any sense. I cannot think of anything which will prevent Roomba from starting a mission.Roombanova wrote:First, I appreciate your help
- vic7767
- Robot Master
Great. 8 Years Old post, but I will post anyway. Had similar issue, Charging fine,Finding Dock Fine, Vacuuming Floor Fine, but when at Charging Dock, it is not leaving when Schedule timer reached or manually pressed Clean.
Irobot support after troubleshoot,told me my warranty long time passed and offered buy back ( was like $50) and buy new unit or buy new with %15off.
Anyway with minimum knowledge in electronics, Did troubleshoot myself and I found what causes .
There a Transistor was shorted to ground, it controls when not to set full charging voltage to pads at idle . If you have pads constantly over 21v, that be it. It should be 3-5v at idle mode.
Transistor type I had on my board STN790A. Check yours first.
P.S. I know my Red and Black wires melted little when Used heat gun, don't forget use some kapton tape
Check the “error6” threads. It’s the cliff sensor. It doesn’t much like the black dock
