T'shooting a Charging Base
Postby lothian » November 18th, 2018, 5:19 pm
My "integrated charging base" does not seem to be working.
I noticed that the roomba stopped returning to the charging base, nor charge when set on to the contacts. The vac checks out as OK, so I suspect the charging base might be the problem.
I believe the green LED on the the charging base is supposed to flash intermittently, probably to indicate power. But this one isn't. When I plug it in, the LED glows steady for 5 seconds, then goes dark and never flashes afterwards.
Do the charging bases go bad..? Is there some better t'shooting procedure I can perform on the charging base to determine if the thing is genuinely facocta?
lothian
Re: T'shooting a Charging Base
Postby RTC » November 18th, 2018, 7:05 pm
One question. Is it plugged into a UPS?
If so unplug it and either plug it directly into the wall or a surge suppressor.
I have a 980 and my base got totally confused when I accidentally plugged it into the UPS in the room (e.g. Roomba could not find home). There is a sentence in the battery section of the manual that operating on a "power converter" can damage the unit. A UPS is one type of "power converter".
Note: iRobot's customer support people are not aware of this! I tried to explain it to them, finally gave up and told them to consult their own engineers.
RTC
Users browsing this forum: ASTMedic, BCCISProf, BrettS, im1kissfan, Ionic, jdong, johnnyh and 350 guests
