Roomba 980 and error 6
Postby sheriff » December 22nd, 2018, 3:35 pm
Hi guys,
I bought a damaged Roomba 980 vacuum cleaner. After pressing the CLEAN button the vacuum cleaner says about error No. 6. I checked and the problem is with the rear right cliff sensor. The sensor is good, I replaced it with another one from a functional vacuum cleaner and it was still the same error. There is no evidence of water damage on the motherboard. Below is the BiT result. Any ideas what can I check?
Code: Select all
key-wakeup
slept for 0 minutes 18 seconds
2017-12-05-1454-L
roomba-mobility/tags/v2.4.4:5775 CLEAN
bootloader id: 3144 411C 1041 2550
robot-assembly: e
sys config: 0 (0b0000000000000000)
mobility-board-revision: rev-c
ui-board-revision: b
audio image status: ok , audio flash format: 5, pack ID: 67, Flash Image Name: El Paso,en-UK,pl-PL
enabled language: en-UK
Ukey-wakeup
slept for 0 minutes 13 seconds
2017-12-05-1454-L
robot-assembly: e
enabled language: en-UK (0)
battery-current-zero 251
BOOTLOADER-ID 3144 411C 1041 2550
ROBOT-ASSEMBLY e
MOBILITY-BOARD-REVISION rev-c
UI-BOARD-CONFIG b
factory-test 0  leds
wait: false
factory-test 1  bumpers
(robot-assembly-ok?) PASS
(and (not (bump-left?)) (not (bump-right?))) PASS
(and (bump-left?) (not (bump-right?))) PASS
(and (bump-right?) (not (bump-left?))) PASS
factory-test 2  cliffs-side
wiff: cliff-left signal 2081  on? 0
wiff: cliff-front-left signal 2077  on? 0
wiff: cliff-front-right signal 1103  on? 0
wiff: cliff-right signal 87  on? 0
wiff: rear-cliff-left signal 2045  on? 0
wiff: rear-cliff-right signal -4  on? 1
wiff: lt-bumper-center-right signal 13  on? 0
wiff: lt-bumper-front-left signal 23  on? 0
wiff: lt-bumper-side-left signal 1874  on? 1
wiff: lt-bumper-right signal 45  on? 0
wiff: lt-bumper-left signal 5  on? 0
wiff: lt-bumper-center-left signal 29  on? 0
wiff: lt-bumper-front-right signal 3  on? 0
(cliff-left-bit?) PASS
(cliff-right-bit?) PASS
factory-test 3  cliffs-front
(cliff-front-left-bit?) PASS
(cliff-front-right-bit?) PASS
factory-test 4  rear-cliffs
(rear-cliff-left-bit?) PASS
(rear-cliff-right-bit?)
factory-test 5  lt-bumper-side
wiff: cliff-left signal 2072  on? 0
wiff: cliff-front-left signal 2069  on? 0
wiff: cliff-front-right signal 2051  on? 0
wiff: cliff-right signal 2040  on? 0
wiff: rear-cliff-left signal 2042  on? 0
wiff: lt-bumper-center-right signal 8  on? 0
wiff: lt-bumper-front-left signal 30  on? 0
wiff: lt-bumper-side-left signal 69  on? 0
wiff: lt-bumper-right signal 9  on? 0
wiff: lt-bumper-left signal 4  on? 0
wiff: lt-bumper-center-left signal 30  on? 0
(and (lt-bumper-left?) (not (bump?))) PASS
(and (lt-bumper-right?) (not (bump?))) PASS
factory-test 6  lt-bumper-front
(and (lt-bumper-front-left?) (not (bump?))) PASS
(and (lt-bumper-front-right?) (not (bump?))) PASS
factory-test 7  lt-bumper-center
(and (lt-bumper-center-left?) (not (bump?))) PASS
(and (lt-bumper-center-right?) (not (bump?))) PASS
factory-test 8  left-wall-follower
(and (lt-bumper-side-left?) (not (bump?))) PASS
factory-test 9  wheel-drop
(wheel-drop-left?) PASS
(wheel-drop-right?) PASS
factory-test 10  omni-receiver
(rcon?) PASS
factory-test 11  binoculars
(valid-code-in-channel? dir-left) PASS
(valid-code-in-channel? dir-right) PASS
factory-test 12  battery-sensors
(battery-voltage-ok?) mV 601  min 431 max 647  PASS
(baseline-current-ok?) mA -189  min -350 max -80 mV -11772 degrees-C -63  PASS
factory-test 13  left-wheel
not (left-wheel-stall?) PASS
(drive-speed-ok? left forward) PASS
(left-drive-current-ok?) mA -833  min -175 max -50 mV -11912 degrees-C -63  FAIL
not (left-wheel-stall?) FAIL
wait: (left-wheel-stall?)
(left-drive-stall-current-ok?) mA -904  min -1040 max -760 mV -11856 degrees-C -63  PASS
wait: (not (left-wheel-stall?))
factory-test 14  right-wheel
not (right-wheel-stall?) PASS
(drive-speed-ok? right forward) PASS
(right-drive-current-ok?) mA -886  min -175 max -50 mV -11939 degrees-C -63  FAIL
not (right-wheel-stall?) FAIL
wait: (right-wheel-stall?)
(right-drive-stall-current-ok?) mA -415  min -1040 max -760 mV -11884 degrees-C -63  FAIL
wait: (not (right-wheel-stall?))
factory-test 15  wheel-encoders
(drive-speed-ok? right stopped) FAIL
(drive-speed-ok? left reverse) FAIL
(drive-speed-ok? right reverse) FAIL
factory-test 16  main-brush
(roller-main-brush-current-ok?) mA -651  min -590 max -100 mV -11995 degrees-C -63  FAIL
(roller-main-brush-current-ok?) mA -622  min -590 max -100 mV -11967 degrees-C -63  FAIL
(main-brush-stall-current-ok?) mA -1347  min -1520 max -1160 mV -11939 degrees-C -63  PASS
wait: (not (main-brush-motor-stall?))
factory-test 17  debris
(piezo-debris?) PASS
factory-test 18  vacuum
(init-vacuum-for-test) PASS
(baseline-current-ok?) mA -195  min -350 max -80 mV -11884 degrees-C -63  PASS
(lex-bin-low-vacuum-current-ok?) mA -810  min -1600 max -980 mV -12023 degrees-C -63  FAIL
not (vacuum-high-current-error?) PASS
(lex-bin-high-vacuum-current-ok?) mA -1411  min -2700 max -1700 mV -12218 degrees-C -63  FAIL
factory-test 19  side-brush
not (side-brush-motor-stall?) PASS
(side-brush-current-ok?) mA -69  min -170 max -10 mV -11967 degrees-C -64  PASS
(side-brush-current-ok?) mA -86  min -170 max -10 mV -11939 degrees-C -63  PASS
wait: (side-brush-motor-stall?)
(side-brush-stall-current-ok?) mA -390  min -540 max -310 mV -11967 degrees-C -64  PASS
wait: (not (side-brush-motor-stall?))
factory-test 20  navigation-sensors
wait: (= nav-factory-test-mode mission-state-testing-bit)
wait: (nav-status-flag? passive-test-ready)
(behaviorlink-gyro-ok?) PASS
wait: (/= nav-factory-test-mode mission-state-testing-bit)
wait: (/= (nav-bit-report.get-flags) -1)
navigation-sensors results
calibration optical-floor-sensor:1 gyro-gain:1 gyro-linearity:1 camera-int:1 camera-ext:1
flags:3 gyro:359 deg odom:352 deg mouse:835 mm arclen:807 mm
current delta odom:7 deg max delta odom:20 deg current delta mouse:28 mm max delta mouse:30 mm
(nav-calibration-ok?) PASS
(optical-floor-sensor-ok?) PASS
(gyro-sensor-ok?) PASS
factory-test 21  optical-bin-sensors
left-near: -1
left-far: 0
right-near: 0
right-far: 0
(optical-bin-sensor-level-ok? left near emitter-low) PASS
(optical-bin-sensor-level-ok? left far emitter-low) PASS
(optical-bin-sensor-level-ok? right near emitter-low) PASS
(optical-bin-sensor-level-ok? right far emitter-low) PASS
left-near: 73
left-far: 870
right-near: 124
right-far: 662
(optical-bin-sensor-level-ok? left near emitter-high) PASS
(optical-bin-sensor-level-ok? left far emitter-high) PASS
(optical-bin-sensor-level-ok? right near emitter-high) PASS
factory-test 22  ext-charger-recovery
wait-true-for-time (32 ticks): (ext-charger-available?)
(ext-charging-recovery-current-ok?) mA 285  min 250 max 350 mV -11745 degrees-C -64  PASS
factory-test 23  ext-charger-on
(ext-charging-current-ok?) mA 1106  min 1000 max 1400 mV -11494 degrees-C -64  PASS
factory-test 24  ext-charger-trickle
(ext-charging-trickle-current-ok?) mA 43  min 40 max 70 mV -11772 degrees-C -64  PASS
factory-test 25  charger-watchdog
(ext-charging-watchdog-current-ok?) mA -8  min -31 max 31 mV -11772 degrees-C -64  PASS
factory-test 26  wifi
t PASS
(wifi-module-ok?) PASS
(wifi-antenna-ok?) PASS
factory-test 27  software
(bootloader-ok?) PASS
(application-ok?) PASS
factory-test 28  bbox-vars
(bbox-test-write-succeeded?) PASS
factory-test 29  serial-flash
wait: (audio-header-crc-done?)
(audio-header-crc-passed?) PASS
factory-test 30  cliff-calibration
(calibration-data-stored?) PASS
factory-test 31  save-factory-test-data
(factory-test-data-saved?) PASS
SUMMARY: START
SUMMARY: DATE-TAG 2017-12-05-1454-L
SUMMARY: BOOTLOADER-ID 3144 411C 1041 2550
SUMMARY: ROBOT-ASSEMBLY e
SUMMARY: MOBILTIY-BOARD-REVISION rev-c
SUMMARY: UI-BOARD-REVISION b
SUMMARY: SW-CONFIG 0 (0b0000000000000000)
SUMMARY: audio flash format: 5, pack ID: 67
SUMMARY: audio image status: ok
SUMMARY: AVAILABLE LANGUAGE(S): en-UK (0) pl-PL (1)
SUMMARY: ENABLED LANGUAGE: en-UK (0)
SUMMARY: cliff calibration: L 20 FL 30 FR 30 R 10 RL 0 RR 0
SUMMARY: FACTORY-TEST INCOMPLETE
SUMMARY: t PASS
SUMMARY: (robot-assembly-ok?) PASS
SUMMARY: (and (not (bump-left?)) (not (bump-right?))) PASS
SUMMARY: (and (bump-left?) (not (bump-right?))) PASS
SUMMARY: (and (bump-right?) (not (bump-left?))) PASS
SUMMARY: (cliff-left-bit?) PASS
SUMMARY: (cliff-right-bit?) PASS
SUMMARY: (cliff-front-left-bit?) PASS
SUMMARY: (cliff-front-right-bit?) PASS
SUMMARY: (rear-cliff-left-bit?) PASS
SUMMARY: (rear-cliff-right-bit?) FAIL
SUMMARY: (and (lt-bumper-left?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-right?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-front-left?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-front-right?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-center-left?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-center-right?) (not (bump?))) PASS
SUMMARY: (and (lt-bumper-side-left?) (not (bump?))) PASS
SUMMARY: (wheel-drop-left?) PASS
SUMMARY: (wheel-drop-right?) PASS
SUMMARY: (rcon?) PASS
SUMMARY: (valid-code-in-channel? dir-left) PASS
SUMMARY: (valid-code-in-channel? dir-right) PASS
SUMMARY: (battery-voltage-ok?) PASS  mV 601  min 431 max 647
SUMMARY: (baseline-current-ok?) PASS  mA -195  min -350 max -80 mV -11884 degrees-C -63
SUMMARY: (left-wheel-stall?) PASS
SUMMARY: (drive-speed-ok? left forward) PASS
SUMMARY: (drive-speed-ok? right stopped) FAIL
SUMMARY: (left-drive-current-ok?) FAIL  mA -833  min -175 max -50 mV -11912 degrees-C -63
SUMMARY: (left-drive-stall-current-ok?) PASS  mA -904  min -1040 max -760 mV -11856 degrees-C -63
SUMMARY: (right-wheel-stall?) FAIL
SUMMARY: (drive-speed-ok? right forward) PASS
SUMMARY: (right-drive-current-ok?) FAIL  mA -886  min -175 max -50 mV -11939 degrees-C -63
SUMMARY: (right-drive-stall-current-ok?) FAIL  mA -415  min -1040 max -760 mV -11884 degrees-C -63
SUMMARY: (drive-speed-ok? left reverse) FAIL
SUMMARY: (drive-speed-ok? right reverse) FAIL
SUMMARY: (main-brush-motor-stall?) PASS
SUMMARY: (bristle-main-brush-current-ok?) disabled
SUMMARY: (roller-main-brush-current-ok?) FAIL  mA -622  min -590 max -100 mV -11967 degrees-C -63
SUMMARY: (main-brush-stall-current-ok?) PASS  mA -1347  min -1520 max -1160 mV -11939 degrees-C -63
SUMMARY: (piezo-debris?) PASS
SUMMARY: (init-vacuum-for-test) PASS
SUMMARY: (lex-bin-low-vacuum-current-ok?) FAIL  mA -810  min -1600 max -980 mV -12023 degrees-C -63
SUMMARY: (vacuum-high-current-error?) PASS
SUMMARY: (ngcs-bin-vacuum-current-ok?) disabled
SUMMARY: (lex-bin-high-vacuum-current-ok?) FAIL  mA -1411  min -2700 max -1700 mV -12218 degrees-C -63
SUMMARY: (side-brush-motor-stall?) PASS
SUMMARY: (side-brush-current-ok?) PASS  mA -86  min -170 max -10 mV -11939 degrees-C -63
SUMMARY: (side-brush-stall-current-ok?) PASS  mA -390  min -540 max -310 mV -11967 degrees-C -64
SUMMARY: (optical-floor-sensor-ok?) PASS
SUMMARY: (gyro-sensor-ok?) PASS
SUMMARY: (behaviorlink-gyro-ok?) PASS
SUMMARY: (nav-calibration-ok?) PASS
SUMMARY: (optical-bin-sensor-level-ok? left near emitter-low) PASS
SUMMARY: (optical-bin-sensor-level-ok? left far emitter-low) PASS
SUMMARY: (optical-bin-sensor-level-ok? right near emitter-low) PASS
SUMMARY: (optical-bin-sensor-level-ok? right far emitter-low) PASS
SUMMARY: (optical-bin-sensor-level-ok? left near emitter-high) PASS
SUMMARY: (optical-bin-sensor-level-ok? left far emitter-high) PASS
SUMMARY: (optical-bin-sensor-level-ok? right near emitter-high) PASS
SUMMARY: (optical-bin-sensor-level-ok? right far emitter-high) untested
SUMMARY: (ext-charger-available?) PASS
SUMMARY: (ext-charging-recovery-current-ok?) PASS  mA 285  min 250 max 350 mV -11745 degrees-C -64
SUMMARY: (ext-charging-current-ok?) PASS  mA 1106  min 1000 max 1400 mV -11494 degrees-C -64
SUMMARY: (ext-charging-trickle-current-ok?) PASS  mA 43  min 40 max 70 mV -11772 degrees-C -64
SUMMARY: (ext-charging-watchdog-current-ok?) PASS  mA -8  min -31 max 31 mV -11772 degrees-C -64
SUMMARY: (wifi-module-ok?) PASS
SUMMARY: (wifi-antenna-ok?) PASS
SUMMARY: (application-ok?) PASS
SUMMARY: (bbox-test-write-succeeded?) PASS
SUMMARY: (audio-header-crc-passed?) PASS
SUMMARY: (calibration-data-stored?) PASS
SUMMARY: (factory-test-data-saved?) PASS
SUMMARY: END
factory-test 0  leds
wait: false
sheriff
Users browsing this forum: BrettS, im1kissfan, johnnyh, Metalworker, vic7767 and 364 guests
