Roomba Dirt Disposal Unit
Postby marquesalan » December 22nd, 2018, 6:28 pm
I have had my i7+ for 34 days now. Today I decided to move the unit to mop and polish the floor. All the way up my wall behind the unit there is a shadow of dirt. There is bit more near the baseboard. I wiped it with a microfiber towel and it all came off easy enough but that can't be good. Not sure this unit is sealed correctly. Does anyone notice any residue around their unit? I talked to iRobot and I am going to see if it continues after I cleaned the wall.
Not sure why the image wants to load horizontally. I tried to rotate it but if you click on it it should enlarge and change to a vertical position.
marquesalan
Re: Roomba Dirt Disposal Unit
Postby vic7767 » December 22nd, 2018, 9:28 pm
I checked mine (it's a little further away from the wall about2 inches) but don't see any signs of dust like you have discovered.
Postby rotorwash » December 22nd, 2018, 10:36 pm
could the motor in the vac create neg ions or static energy causing attraction of dust on the wall?
rotorwash
Postby vic7767 » December 23rd, 2018, 12:27 am
That may be the purpose of the new additional grounding attachment installed on the i7.
Postby marquesalan » December 23rd, 2018, 7:49 am
What additional grounding attachment? Mine is a standard plug. It could be static but how do you keep that under control? The told me to put the base up against the wall. The baseboard touches the bottom of the base but the rest is open.
marquesalan
Postby RTC » December 23rd, 2018, 9:24 pm
marquesalan wrote:What additional grounding attachment? Mine is a standard plug. It could be static but how do you keep that under control? The told me to put the base up against the wall. The baseboard touches the bottom of the base but the rest is open.
There are many effective ways to control static. One way is grounding equipment through a high impedance (to prevent potentially dangerous shocks). However air ionizers and humidifiers are often much more effective as they both make the air itself slightly conductive, continuously bleeding off any static charges before they buildup. These even work where the case of the equipment is plastic, which grounding usually cannot discharge as most plastics are very good insulators.
Postby vic7767 » December 23rd, 2018, 11:27 pm
What I'm talking about is a small bristle brush located behind the left rear cliff sensor that is an anti-static device that is grounded to the robot chassis via a single wire.
Postby redpoint5 » December 24th, 2018, 3:29 am
Most forums autorotate photos to landscape. If you want the photo to show up properly, take it in landscape, which generally you should be doing anyhow unless you’re taking a portrait. You’ll have to crop your photo so the width is at least 1 pixel wider than the height.
redpoint5
Postby marquesalan » December 24th, 2018, 8:56 am
I was wondering what the small brush was for! Maybe mine is not working. All I know is this is not acceptable. Thanks for the photo advice too, it's not that big of a deal if it's sideways. As long as people can see it.
marquesalan
Users browsing this forum: im1kissfan, joanquro, jramer, lanchez, leonicholson, Metalworker, RTC, TechGuy and 331 guests
