650 Right Wheel Not Moving ERR 10
Postby leonicholson » December 31st, 2018, 8:12 pm
After starting, turns in a constant clockwise circle. If I press either bumper, it tries to turn for an instant, then returns to clockwise circle.
The right wheel (by the side brush) is completely inoperative. After a while, it stops and says "Error 10, move Roomba side wheel to clean".
I checked the wheel by exchanging with a good 595 wheel assembly - same results. Both wheels turn with about the same resistance. The Roomba is very clean.
It seems like the wheel is getting no power at all.
leonicholson
Re: 650 Right Wheel Not Moving ERR 10
Postby vic7767 » December 31st, 2018, 11:09 pm
You can assume that the right wheel has a defective component in the H-bridge control circuit. Use the Advanced search for H-Bridge by author a1robotrepair for troubleshooting.
Postby leonicholson » December 31st, 2018, 11:50 pm
Thanks. Suspected the H-Bridge from posts I have read here in the past.
May play with it for a bit.
No risk, as it is new, was only $40 and came with all the accessories. (Perfect for parts)
leonicholson
Postby leonicholson » January 1st, 2019, 12:19 am
Also, long ago in one of your posts:
Re: Roomba 655 main brushes not spinning
Postby TechGuy » November 3rd, 2018, 3:58 pm
Motherboard of 500 and 600 series Roomba are interchangeable. I have not worked 600 series motherboard with the WiFi support. I don't know whether they can be used in your Roomba.
Would a 595 motherboard work in a 650?
Neither have WiFi.
leonicholson
Postby vic7767 » January 1st, 2019, 12:43 am
I have not swapped that particular model but it should work.
Users browsing this forum: im1kissfan, joanquro, jramer, leonicholson, RTC, TechGuy and 329 guests
