iRobot Wifi Connected Diagnostic Software?
Postby bartkwan23 » January 10th, 2019, 2:17 am
Is there any software that can run diagnostic on the Wifi Connected Series?
I think the old models have a USB port, but the newer ones doesnt.
How do you guys diagnose the wifi roombas?
bartkwan23
Re: iRobot Wifi Connected Diagnostic Software?
Postby vic7767 » January 10th, 2019, 10:36 am
No one has posted any info on how to access the BiTs program on the new i7.
Postby bartkwan23 » January 11th, 2019, 5:22 am
what about the older ones? like 690, 980, 890? any luck?
bartkwan23
Postby vic7767 » January 11th, 2019, 10:31 am
bartkwan23 wrote:what about the older ones? like 690, 980, 890? any luck?
Yes, key presses can be used to access the Built in Tests.
Postby bartkwan23 » February 18th, 2019, 11:23 am
where can i get the key presses? couldnt find it.
bartkwan23
Postby vic7767 » February 18th, 2019, 12:54 pm
The iRobot Service manual contains the key press sequence that will work on all R3 models except the new i7. Here is a URL that contains that document. Please do not use the Auto test key sequence. The MANUAL mode is your best choice for testing the Roomba.
https://choisirsonaspirateur.info/wp-co ... Manual.pdf
Postby bartkwan23 » February 19th, 2019, 3:47 am
vic7767 wrote:The iRobot Service manual contains the key press sequence that will work on all R3 models except the new i7. Here is a URL that contains that document. Please do not use the Auto test key sequence. The MANUAL mode is your best choice for testing the Roomba.
thank you so much! great help!
bartkwan23
Users browsing this forum: clone1008, fufu, jdong, johnnyh and 171 guests
