980 Filter door latch broke
Do you have a picture?
Any particular epoxy?
Done
doc280
Many thanks!
Will do that.
doc280 wrote:...
Users browsing this forum: drunkpenguin, im1kissfan, Ionic, jdong, johnnyh, kosmoi, leonicholson, Mattb83, Miles267, RockinRay, someoneclever, vic7767 and 381 guests
