805 HEPA Filter Mod
PostPosted: February 13th, 2019, 5:51 pm
by leonicholson
Added a piece of pre-filter before the HEPA. No apparent affect upon suction, protects the HEPA from hair and large particles and is much easier to clean.
Re: 805 HEPA Filter Mod
PostPosted: February 13th, 2019, 6:47 pm
by babakonda
I had some replacement filters from China which had a thin metal net/mesh on one side, guessing that should stop the hair and larger debris from entering the filter.
What did you use to make this?
PostPosted: February 13th, 2019, 7:00 pm
by leonicholson
A piece of Whirlpool air cleaner pre-filter. Carbon impregnated fiber.
PostPosted: February 14th, 2019, 4:55 am
by babakonda
I’m having thoughts of using carbon cat litterbox filter for the same purpose. They’re thin yet effective.
PostPosted: February 14th, 2019, 10:15 am
by RTC
babakonda wrote:carbon cat litterbox filter
The "carbon" in these is activated charcoal granules, for absorbing odors.
There are odors in the litterbox. Are there odors in your carpet?
PostPosted: June 20th, 2019, 3:27 pm
by I'mNotARobot
Is it possible to mod a 5xx AeroVac/6xx bot with the AeroForce gen2 vacuum motor and impeller?
PostPosted: June 20th, 2019, 6:54 pm
by leonicholson
I don't feel it necessary for a 5xx or 6xx, as the cheap standard filters do the same thing.
I came up with this to pre-filter the HEPA filters on our 805 and 980.
I now just use the pre-filter with an empty HEPA filter frame, as I feel HEPA filters on a vacuum clear have little effectiveness.
