I7+ Disable clean base
PostPosted: March 9th, 2019, 6:58 pm
by dfp
Re: I7+ Disable clean base
PostPosted: March 10th, 2019, 9:45 am
by RTC
PostPosted: March 10th, 2019, 7:34 pm
by dfp
PostPosted: March 10th, 2019, 7:49 pm
by RTC
PostPosted: March 10th, 2019, 7:58 pm
by dfp
around 30w charging
PostPosted: March 11th, 2019, 1:06 am
by RTC
dfp wrote:around 30w charging
PostPosted: March 11th, 2019, 5:04 am
by dfp
PostPosted: March 11th, 2019, 10:54 am
by RTC
PostPosted: March 12th, 2019, 6:27 am
by dfp
PostPosted: March 12th, 2019, 9:27 pm
by RTC
Wonderful.
PostPosted: March 12th, 2019, 10:51 pm
by Brett
PostPosted: March 13th, 2019, 2:56 am
by RTC
PostPosted: March 13th, 2019, 4:58 am
by dfp
PostPosted: March 13th, 2019, 8:35 pm
by Brett
PostPosted: March 13th, 2019, 10:49 pm
by RTC
