Roomba 880 bumping into lighthouses - only on one side
Postby mcgroarty » March 28th, 2019, 6:47 pm
I have a Roomba 880 that bumps into or ignores lighthouses. It only happens occasionally although it's happening increasingly often. It only happens when passing them on the right side, I've yet to see it happen while the lighthouse is to the left of the Roomba. The Roomba and the two lighthouses both have new (<1 month) batteries.
How should I troubleshoot this?
I do see some dust accumulation underneath the cliff sensor plastic on the rightmost sensor. Do the cliff sensors underneath the unit also factor into detecting the lighthouse? Or is the front sensor atop the bumper the only one I should be concerned about?
mcgroarty
Re: Roomba 880 bumping into lighthouses - only on one side
Postby RTC » March 28th, 2019, 9:15 pm
mcgroarty wrote:I have a Roomba 880 that bumps into or ignores lighthouses.
Clean the little round "periscope" sensor on the top front edge. This is the ONLY sensor used to "see" lighthouses/virtual walls and the home base. (does it also ever have problems returning to the home base?)
RTC
Postby vic7767 » March 28th, 2019, 10:41 pm
A common fault is that one of the three wires that connect the top mount IR sensor to the main circuit board has broken. Disassemble the front bumper and check for broken leads.
Postby a1robotrepair » March 28th, 2019, 11:05 pm
Remove the battery cover, battery and bottom of bot.
Remove the bottom 10 screws of the bumper retainer and retainer.
Carefully separate the bumper about an inch away from bot and remove the 2 screws from the RCON.
Separate the RCON from the bumper, take note of proper orientation of RCON.
In the top middle of the front of the bot you will notice a rectangular black plastic piece.
The directional sensors are recessed on each side of the divided rectangular piece.
Blow them out and use a soft paint brush to clean the dust from inside the bumper.
You can also dampen a q-tip with alcohol and clean the sensors a little better.
Do not use water! The sensors and rectangular separator are soldered to the circuit bosrd.
Hopefully this works and you don’t have a bad sensor or sensor circuit.
Users browsing this forum: ASTMedic, BCCISProf, BrettS, cdogstu99, dariuszbednorz, johnnyh, Miles267 and 370 guests
