Battery recommendations
Postby guvnaar » April 3rd, 2019, 3:48 am
Any new battery recommendations for these following 8 year old Roombas?
530 - Current Battery model:3000 Ni-MH
630 - Current Battery Ni-Cd 2200mAh
3500NiMH batteries on ebay are around US$30 and Lithium range between US$40 and $80 None of them explicitly stat they have cell balancing tech so its a little confusion as to what to try?
https://www.ebay.com.au/itm/142388521462
https://www.ebay.com.au/itm/14-4V-4500m ... 2187048464
guvnaar
Re: Battery recommendations
Postby Brett » April 3rd, 2019, 7:54 am
As far as batteries are concerned, those two machines are the same (ie battery pick would be the same)
If you are going Nickel, steer away from the higher Ah ratings - I find that the chemically fragile and don't last.
If you are going Lithium, steer away from anything cheap. It used to be ONLY ANewPow and LithiumPower that had cell balancing, there are now some cheaper alternatives that do have it too (I stock one of these and these seem pretty good so far).
Don't cheap out - it's not worth it.
Postby guvnaar » April 3rd, 2019, 8:30 am
Thanks decided to go for the NiMh what would you consider the higher Ah rating I should avoid?
guvnaar
Postby leonicholson » April 3rd, 2019, 10:00 am
I've had good results with one like this:
https://www.ebay.com/itm/Powerextra-3-8 ... ondition=3
leonicholson
Postby Brett » April 5th, 2019, 1:04 am
guvnaar wrote:Thanks decided to go for the NiMh what would you consider the higher Ah rating I should avoid?
I think 3300mAh to 3500mAh is the sweet spot.
This is just my 5c opinion based on my experience - I can not back it up with any science.
(-8
Postby leonicholson » April 5th, 2019, 1:32 pm
Do consider the brand. Both PowerExtra and Tenergy seem to last a long time for us.
leonicholson
Postby mfortuna » April 6th, 2019, 9:38 am
A comment on NICADs. I raced RC vehicles for years and NICADs are more tolerant of abuse (over discharge and charge). Although you may not get long run-time the NIMH battery may last longer.
Users browsing this forum: Aniseedvan, jdong, jomo, KeldBroe, mobzd, someoneclever, vic7767 and 207 guests
