i7 room cleaning oddity
Postby Hazel5511 » May 14th, 2019, 7:49 pm
I've had my i7+ for a couple of weeks. I have successfully mapped the main floor and created labeled specific rooms etc. I'm noticing something really odd. When I send Hazel out to clean an individual room or rooms, she spends about 5 minutes cleaning areas around the home base before setting out to the room she's supposed to clean. Any idea why? I've attached the map image that shows where she cleaned when I asked for the master bathroom to be cleaned.
Hazel5511
Re: i7 room cleaning oddity
Postby RTC » May 14th, 2019, 9:12 pm
Hazel5511 wrote:I've had my i7+ for a couple of weeks. I have successfully mapped the main floor and created labeled specific rooms etc. I'm noticing something really odd. When I send Hazel out to clean an individual room or rooms, she spends about 5 minutes cleaning areas around the home base before setting out
Maybe she just wants to keep her own home clean before leaving for work. :wink: :wink:
Postby wat » June 13th, 2019, 5:45 am
maybe some sort of diagnostic/functional test before heading out to do the job
wat
Postby bytemaster0 » June 13th, 2019, 2:08 pm
Probably an unideal location for the home base. If there are obstacles of any sort around it, the bot may be trying to assess its location first. Also, if you pick up the bot for any reason, it has to re-establish which floorplan it is using, in the case that you have multiple. Try relocating the home base to a more open area without any nearby walls, corners, or other obstacles.
bytemaster0
Postby BoxerBoi76 » June 14th, 2019, 5:02 pm
Hazel5511 wrote:I've had my i7+ for a couple of weeks. I have successfully mapped the main floor and created labeled specific rooms etc. I'm noticing something really odd. When I send Hazel out to clean an individual room or rooms, she spends about 5 minutes cleaning areas around the home base before setting out to the room she's supposed to clean. Any idea why? I've attached the map image that shows where she cleaned when I asked for the master bathroom to be cleaned.
Call support and tell them you want the 2.0.9 firmware pushed to your device. Tell them you’re having mapping issues and it’s wondering around needlessly.
2.0.9 is a vast improvement - just had it pushed to both of my i7’s and it’s a night and day difference.
BoxerBoi76
Users browsing this forum: BrettS, im1kissfan, jdong, johnnyh, leonicholson, Metalworker, someoneclever, tsmith, vic7767 and 377 guests
