Numerous 595 problems.
Postby leonicholson » June 8th, 2019, 1:41 pm
I just received a very clean 595 that clicks with when trying to charge and the on/off button flashes red three times. This is the same on dock or with side charge jack.
When I put in a good battery, the drive wheel farthest from the spinner starts running with the on/off switch not pressed or illuminated.
No Err messages, beeps, etc.
I put in a proven drive wheel modules without affect.
Can't reset it, as it immediately starts running without powering on and won't shut off without removing battery.
Toast?
leonicholson
Re: Numerous 595 problems.
Postby vic7767 » June 8th, 2019, 9:53 pm
New board or look for water damage to the original board. Clean with 99.9% Isopropyl Alcohol on visible damaged areas of the board using a toothbrush.
Postby leonicholson » June 9th, 2019, 12:48 pm
I may try cleaning it, although I suspect there's a low success rate. :)
When you clean the motherboard with 99.9%, do you soak it before brushing?
leonicholson
Postby vic7767 » June 9th, 2019, 1:59 pm
I usually spray suspect areas from a spray style container then scrub with a small brush and wipe with a cloth.
Postby leonicholson » June 9th, 2019, 2:11 pm
Thanks.
Disassembled the Roomba today and cleaned the motherboard with alcohol and brush - to no avail.
The insides and motherboard were clean and showed no physical problems, but it has obviously "bit the dust".
It is amazing how well made the Roombas are and how easy they are to access.
leonicholson
Users browsing this forum: ASTMedic, b55er, BrettS, fufu, im1kissfan, johnnyh, KeldBroe, mobzd, Tripmeister and 418 guests
