S9 side brush
S9 side brush
Postby Rift » June 21st, 2019, 11:07 pm
Is anyone else noticing the side brush on the S9+ getting mangled when it comes back to the clean base? Iv seen a few reports where people are saying it’s the carpet that’s mangled it but from what I can see it gets caught up due to friction from the silicone when coming back to the clean base.
This couldn’t have been missed during testing because it’s so blatantly obvious when it happens.
https://ibb.co/vLdWQZV
https://ibb.co/FKPPZTG
https://ibb.co/gTJVxrR
The last image is the way it should be sitting but I had to unfurl it in order for it to sit that way.
Rift
Re: S9 side brush
Postby Transammatt » June 22nd, 2019, 12:24 am
I think they rushed it to market. Mine was messed up after the first run. I called iRobot about it not moving well on carpet, told them about the side brush, they said it is normal.
Transammatt
Re: S9 side brush
Postby piokrza » June 23rd, 2019, 12:16 pm
They will re-design it in the next Roomba gen next year...stay tuned! Until then, get rid of old fashion carpet across your home. At now area rug & hard floor rules.
piokrza
Re: S9 side brush
Postby RTC » June 23rd, 2019, 6:34 pm
piokrza wrote:They will re-design it in the next Roomba gen next year
Would that be the S9.2 or S10? :) :? :lol:
Re: S9 side brush
Postby ps0001 » June 24th, 2019, 8:02 am
It'll be called the f11. It will feature a stronger side brush and a pentagonal shape. It will cost $2,200 and its Clean Base and extractors will be incompatible with either the i7 or s9. Keep an eye out for it in stores as soon as the return period for the s9 is over. :P
ps0001
Re: S9 side brush
Postby RTC » June 24th, 2019, 11:47 pm
ps0001 wrote:It will cost $2,200
Does it come gold or platinum plated??!!??
Re: S9 side brush
Postby ps0001 » June 25th, 2019, 8:34 am
RTC wrote:Does it come gold or platinum plated??!!??
Even better, a coated plastic that highlights the smallest of scratches!
ps0001
Re: S9 side brush
Postby RTC » June 25th, 2019, 10:32 am
My 980 already does THAT! At least it only has one of them in the camera window.
Replaced my failing $150 couch with a new modular $2000 couch to prevent any more damage to the 980!
Re: S9 side brush
Postby leonicholson » June 25th, 2019, 10:00 pm
Transammatt wrote:I called iRobot about it not moving well on carpet, told them about the side brush, they said it is normal.
I guess "normal" is the new term for "it's now your problem".
Re: S9 side brush
Postby Julian » June 26th, 2019, 4:49 am
With all the tinkerers on this forum I wonder if anyone has been tempted to try to graft a 900 or i-series side brush onto an s9! The official s9 side brush, once the bristles are cut off, supplies the hub and screw for attaching to the robot in a way that would not void any warranty. I suspect that because of the way the s9 bristles face downwards an older brush would not reach the ground and would simply spin in the air but maybe using a longer fixing screw (of the same diameter as the original screw) and using some spacers (e.g. washers) to space the side brush slightly down from the base of the robot such that it does contact the ground might solve that issue.
Whether it would work any better than a damaged official s9 side brush is another matter but it might be an interesting experiment, one that I might try myself when I get an s9 and once I get a feel for how quickly my side brush is getting trashed in my environment.
Julian
Users browsing this forum: BrettS, jdong, lanchez, leonicholson, Per L, vic7767 and 450 guests
