iRobot 675 error
iRobot 675 error
Postby masterjedi73 » July 5th, 2019, 8:57 am
My 675 keeps say "Error 1: Move robot to new location, then press clean to restart". I've done that many times. I've cleaned out the bottom, moved the wheels up and down, cleaned all hair out of it. I can't get it to clean.
Thoughts?
masterjedi73
Re: iRobot 675 error
Postby vic7767 » July 5th, 2019, 11:12 am
Time to discover what sensor is complaining. Go to this URL: http://choisirsonaspirateur.info/wp-con ... Manual.pdf
Read through the manual and learn how to perform the MANUAL Built in Tests. Then you will be on your way to a solution.
Postby masterjedi73 » July 14th, 2019, 3:10 pm
Thank you, but the manual is for the 500 series. I have the 675.
masterjedi73
Postby vic7767 » July 14th, 2019, 5:48 pm
The 675 still has the same sensors, motors and all are still tested using the 500 model Built in tests that are resident in your 675 firmware.
Users browsing this forum: KeldBroe and 108 guests
