New 5XX Foolproof Cliff Sensor Work around
Re: New 5XX and 700 Foolproof Cliff Sensor Work around
Postby She'sMariaToMe » June 6th, 2012, 6:44 pm
Vic's copy paper work around worked great for my new Roomba 770" Maria". I have about 1400sf of hardwood floors and about 1200sf of Saltillo tile in the kitchen and halls. I noticed immediately that Maria didnt like my traditional Persian rugs that have black boarders. I have these rugs throughout my home and this was going to be a big problem.
After doing a little reading at the Irobot site I decided there had to be a way to defeat such a simple system. My great idea was masking tape over the cliff sensors. My home is a one story so I'm not concerned with her taking a fall. After my masking tape test failed I decided I would call Irobot. I was very disappointed when the tech told me there was nothing that could be done. I was really expecting a dip switch issue or even a software upgrade,and that would be that. Ok,so thats what the internet is for and bam, here I am.
I've allowed Maria to run a full cycle and she now Loves the persion rugs. She also found her way home but I could have lived with that.
My Mother has a 5xx that she dosnt use anymore due to clutter mainly. I think I will bring her home with me to do the guest end of the house. I think I will name her "Rosarrio", or maybe "Rosita".
Anyway, THANKS to everyone for your input. It's people like you that makes the internet infinitely usefull.
MeAndMariaohandRosita :thanks:
She'sMariaToMe
Re: New 5XX Foolproof Cliff Sensor Work around
Postby RSargeant » October 6th, 2012, 10:29 am
Here's a slightly new variation on cliff sensor issues. My 560 suddenly fell out of love with the power dock and refused to couple! It would wiggle towards the dock as usual, mount the lip of the dock and then just stop. After a few seconds it would sound "unhappy" but not attempt to re-dock. Net result, battery didn't get recharged.
The inside of the front 2 cliff sensors seemed very dusty. Demolished the Roomba (boy, you have to take a LOT apart to get those sensors out), cleaned out the inside of the sensors, re-assembled - fixed!
Our whole apartment has dark wood floors and no cliffs, so my theory is that the black plastic of the dock was just darker enough together with the reduction in reflected infrared caused by the dust for the firmware to yell "cliff" and stop the Roomba.
Maybe useful to others.
Richard
Switzerland
RSargeant
Postby robog33k » December 30th, 2012, 7:08 pm
My wife got a Roomba 650 for Christmas, and one of its first tasks was to vacuum the dining room. In our dining room is a small carpet in front of the door (little brother to the bigger ones in our living room and foyer), with a wonderful variety of geometric patterns on it. Patterns that caused the poor little 'bot to totally spaz.
Looking around on the Interwebs, I found this forum, and this thread (huzzah! Love this forum!!) And while the concept espoused here made perfect sense to me in general terms, the engineer in me was not satisfied with the solution as it was presented. So I set out to craft, what I think, is a better solution.
But first, why it didn't make sense to me. The cliff sensors each are made up of a pair of infrared (IR) transmitters (phototransistor) and receivers (photodiode), and that pair is separated by an opaque plastic "wall" between the 2 of them; look closely at your 'bot and you can see it running right down the middle, and extending just a tad (technical term) above the transparent window. Putting a piece of paper or aluminum foil over the window would do nothing to channel the IR light between the 2 sides; in fact, it would be more prone to block it. I'll speculate that the aluminum foil that worked for folks was loose and crinkly, with lots of little channels between the 2 sides. The calls for "high quality white paper" leads me to think that people were using thicker fiber stock, that gave the IR light plenty of room to channel through the paper, between the 2 sides of the sensor's chambers.
So, let's take a look at the IR light. My wife's phone just happens to have an IR mode, so here is the light being emitted from the transmitter:
What I figured we'd need was a "channel" of some sort, that would funnel the light from the transmitter's side to the receiver's side. So I tried a couple different pieces of straw to see which reflected the light best, and settled on this one:
What is it? It's the hard plastic straw from a water bottle. This particular one's made by CamelBak, and you can buy spare straws at various sporting good stores (I've bought mine at Dick's and Mountain High).
And it turns out, after trimming one to fit my bottle, I had just enough left over to be used for this task!
I cut this piece into 2 pieces, each about an inch long.
Then, I proceeded to cut them in half. After cutting off the tip of my left index finger by using a Really Sharp kitchen knife (I'll spare you the picture of blood all over the kitchen), I then got out my metal shears and cut them down one side:
then used the Really Sharp knife to cut the other side:
I now had 4 pieces of "IR channel" to apply to the 'bot's sensors.
I put a piece of scotch tape on each, with about ½" of overhang on one side, and ¾" on the other. The shorter piece went on the inside of the sensor, the longer side went on the outside.
Et voilá, the final result…
Tips:
  • Make sure the tape is secure; I've already had one IR channel fall off because I didn't firmly press the tape down, and have a second about to come off too.
  • If you use a different material, find a camera that will help you determine if the material is reflective in the infrared. Just because a material is opaque to your eye does not mean it won't be transparent to IR.
  • Be careful using sharp knives. No, really!
I'm toying with the idea of supergluing these pieces in place; since they're open-ended channels, I can easily use a can of air to blow out any accumulated dust within.
Hope my adventure helps someone! Even if it's just to remind people to be safe when playing with knives! :D
robog33k
Postby vic7767 » December 30th, 2012, 7:20 pm
robog33k, nice update to this thread. Anything surface wise that can reflect the IR signal back to the receiver is a great work-around.
Postby gregjsmith » December 30th, 2012, 9:07 pm
I have used the same straw trick, except I use regular stars found from fast food drinks.
I tape them on with blue painters tape with the bottom cover off, then put the cover on which overlaps the tape.
gregjsmith
Postby iMayne » January 4th, 2013, 8:44 am
Vic, what's the reason for the two white papers just above the battery?
UK Business Coming Soon
iMayne
Postby vic7767 » January 4th, 2013, 12:01 pm
That was to demonstrate the shape of the paper inserts.
Postby Metroshica » April 16th, 2013, 1:19 am
Created an account just so I could thank robog33k! I tried all sorts of methods, aluminum foil, masking tape, paper suggested by vic, and I could not get my Roomba to work. I only succeeded in my Roomba not moving at all and consistently telling me to "move roomba to new location, then press clean to restart". I just happened to have a water bottle similar to robog33k, cut it up and applied it like he said, and it worked perfectly! Thank you very much for this solution, my wife and I just bought a beautiful new rug, but the black in the design completely befuddled our Roomba 560. Did not want to go have to buy a manual vacuum, you saved us a good amount of money robog33k. :dance: :dance: :dance:
Metroshica
Postby aurickle » May 24th, 2013, 3:07 am
I'm so glad I found this thread! I love my Roomba but it has always had trouble with certain areas of my rugs. I'd always thought it was just not liking the wires that run under the rug to my surround sound speakers, although that didn't make a whole lot of sense to me because the resulting bump is pretty much nonexistent. I never thought of the cliff sensors being the problem, but as soon as I read this I realized that had to be the case.
I tried the foil method initially and my Roomba immediately demanded to be moved. But robog33k's suggestion gave me an idea. I didn't have any straws around -- but I do have some zip-lock baggies. It occurred to me that the channel that lets these lock should work the same way as a straw, but even better because of how little depth the channel has. It would create a tunnel for the light to reflect through, but with a profile almost as thin as the unmodified unit.
I simply opened a baggie and cut the channel strip from one side. That I cut into six short lengths (because the 700 series Roomba has six cliff sensors). I laid each segment onto a sensor with the ridges facing down, creating a very thin tunnel. Then I used silver duct tape to fasten the segment to the Roomba.
It worked a treat! I put the Roomba onto my area rug in the section where it ALWAYS gets hung up. I think my next step will be to shellac the edges of the duct tape so as to guarantee that they'll never peel up. That will also remove any risk of dust getting trapped. I know it would prevent me from ever being able to send the Roomba in for warranty work. To me that's a small price to pay for FINALLY not having to listen for the Roomba to complain about the rug anymore.
Thanks for the suggestions!
aurickle
Postby bignall » October 24th, 2013, 11:21 am
Thanks so much for this solution! I just got my second Roomba (first one was one of the early models and couldn't handle the pet hair in my home so it didn't last long).
I have an area rug that I love, but it has a series of rectangles, each with a black line around it, so what did Roomba do, it thought the black lines were cliffs and got stuck in a rectangle and kept (unsuccessfully) trying to find a way out, round and round it went. That one square got cleaned really well, but nothing else!
I have no stairs or drop offs, so blinding the cliff sensors is no problem :D .
Thanks again!
bignall
Postby marcyzac » July 28th, 2014, 1:39 pm
Wow!! So glad I found and read this post and series of replies! We tried ALLLL the ideas of metal tape, foil, paper, etc. and none of them worked...I was about to load our new Roomba 770 back in the box and return it. We were (and still are) VERY annoyed the whole "dark carpet" problem was not disclosed while we were researching the robots. I too did not have a plastic straw but I thought what is it going to hurt to try the Ziploc bag channel idea. It ABSOLUTELY worked like a charm! RIGHT OFF THE CHARGER! I used scotch tape and a gallon size bag zip channel cut into 1 inch sections. I had to trim around the cut section and the sensor near the spinning brush wants to fall off so I have had to adjust and re-tape that section. LOVE LOVE LOVE the internet!
marcyzac
sensor deactivation suggestion
Postby dawnth » June 15th, 2015, 8:52 pm
For those who have carpets with dark geometric shapes that confuse the sensors into thinking the Roomba will drop off a cliff. I found a great and simple solution.
Simply duct tape a shiny quarter on each sensor, covering the entire sensor. Works like a charm. Hope this helps.
dawnth
Postby jabaldwi » December 1st, 2015, 9:23 am
I just bought a 980. Wish I was as smart as I thought I was and researched first. Yep, black areas on area rugs. I spent 30 minutes working on the zip-lock baggie "zip channel" trick (cut strips of the zip channel then duct-taped them in place. Roomba refuses to move: "error 6! error 6! move robot to a new location!" Is this version harder to fool? Is the ziplock channel too small? In the photo below peeled the tape off one of the back sensors and laid it upside down so you can see the size of the channel.
jabaldwi
Postby a1robotrepair » December 21st, 2015, 6:34 pm
I like this method. Remove the cliff sensors. Remove the clear plastic lens portion from the black portion of the cliff sensors. Slide your fingernail between the black and clear clips on the side carefully pull apart as the clips are very flimsy and break easily. Cut out black center of clear portion and reassemble. Your cliffs sensors will not stop for a cliff or dark floor anymore. Your Roomba will fall down the stairs now!
Postby jbarishman » March 14th, 2017, 7:36 pm
I have a 669, and this did not work, it kept backing up and then gave error 6 then error 1. Any Ideas?
jbarishman
Postby vic7767 » March 14th, 2017, 8:22 pm
You can put your Roomba into the Built-in-test mode and test all your cliff sensors to see which one is still detecting a cliff in error.
Postby Pilony » September 24th, 2018, 2:40 pm
HELP!!!
I bought my 980 in the US and brought it with me to Israel. It was never used before now. I plugged it in and set it up. It downloaded the lates firmware and all is apparently good to go.
BUT.....
When I hit Clean, it responds with "Error 6. Move to a different location".
So, I called CS and they inform me that this unit is actually "used" and two years old. So no warranty.
I have tried all of the work arounds offered here and other places to no avail. I now have a $700 door stop.
Can anyone make a suggestion to me? One interesting note. I accidentally tripped the breaker that the 980 is plugged into and it powered up and took off to start cleaning. but about ten seconds in it stopped and gave the Error 6 message again.
PLEASE. I'm a bit desperate.
Pilony
Postby vic7767 » September 24th, 2018, 3:01 pm
You can order cliff sensor assemblies online at places like ebay & Amazon. You will be able to identify which sensor is complaining by placing your 980 into the BiTs mode and test the sensors.
Postby Pilony » September 25th, 2018, 12:38 am
Noobie, I am. How do I put it in BITS mode and what do I look for?
Pilony
Postby vic7767 » September 25th, 2018, 11:19 am
Head over here and download the Service manual. Although for the 500 models, it also applies to your model.
http://choisirsonaspirateur.info/wp-con ... Manual.pdf
Read through the document and learn how to place your Roomba into the MANUAL BiTs mode and then you can test your robot.
Users browsing this forum: ASTMedic, BrettS, jdong, KeldBroe, Metalworker, mobzd, vic7767 and 366 guests
