Read through this old thread. It may provide some guidance. If you want more reading, just do a RR Advanced Forum Search for 'pumpmotor' (no space between words).Jeff Carver wrote:I'm trying to get a used Scooba 5900 working. The problem is that the pump stops working erratically. ...Ideas, anyone?...
Test-12, I presume.Jeff Carver wrote:... doing self-... tests ... The pump runs as long as I want it to on the pump test.
That ceasing of fluid ejection, coupled with "no indicator lights" and this next statement tends to imply:But ... on a cleaning cycle, and after a couple of minutes, it stops pumping fluid. (No indicator lights.)
a) solution is still wetting the fluid-sensor (located just below the lance), andWhen I return to diagnostic tests, I might have to thump it or shake it, and then it runs again,...
Test-12 does slow the pump-speed, starting at a high-rate, and throttling to a slower speed. I have no more detail about that function....and then it runs again, as long as I like. (Ah--but although the pump keeps running on the diagnostic, when I lift it up, I see the actual squirting tapers off. Doesn't quite stop, but becomes pretty minimal.)
Apparently so, if the Tank has not run a recent mission, and even to some extent if it has! I just tried the draining operation on my Tank, which has been drying for about a week, and found the quick curtailment of flow. The Clean chamber had been filled to the max with plain water.The inlet lance appears fine. But ... when {I manually open} the tank poppet valve, the liquid runs for a couple of seconds, then tapers off and stops. If I shake or tip the tank and try again, I once more get a flow, but only for a few seconds. Is that normal?
I think flow should continue, as long as you keep the bot in Test-12....Anyway, I'm wondering if the flow from the tank should be continuous on that manual test, and if maybe a problem with that is causing the unit to go into drying mode when the fluid flow stops. ...
More details are needed.
Test-12, I presume.
That was a lot of work!Jeff Carver wrote:And the answer is...it worked for maybe half an hour, then stopped pumping. I terminated the cycle, and started a new cycle, and no pump sound. ...
It would be nice to know whether voltage still exists across the motor terminals after the pump has halted.
If voltage exists, that would confirm another member's assertion that the motor has a normal dead-spot somewhere in its revolution (I don't subscribe to that for a 3-pole motor as used here).
If voltage across the motor has gone to zero, that would indicate the controller has terminated drive to the pump-motor--possibly due to an over-current condition.
To gain such knowledge about the applied motor-voltage, you would have to connect a two-wire test cable to the motor's terminals, thread the cable though some handy slits/vias of the robot's assembly, so the cable could connect to a small DVM taped to Scooba's Tank!
Red-leads of both motors directly connect to raw battery voltage. The major difference will be in the signal train from the MCU. In the Roomba, the ON/OFF signal is simple bi-state, HI/LOW, while Scooba must use one of the MCU's PWM outputs in order to vary pump-motor speed.
That information may help you see where your voltmeter will be connected.
You may have noticed there are four wires in the Pump-Motor cable. All four terminate on a row of solder-pads on the motor's EMI_PWB. BLK attaches to terminal #1, and RED to #2. Those two terminals constitute option-1 for your test-cable's connections. The terminals are small and close together, requiring caution to not end up bridging the two. You would be soldering to the up-turned ends of the cable-wires.Jeff Carver wrote:... I would like to try the voltmeter attached to pump motor experiment. However... If one of you ... can ... explain exactly where to attach voltmeter leads on the motor, I'd be willing to give it a try. ...
remove the conformal-coating material from the terminal you intend to solder to,
Slip the keen edge of a thin knife-blade under the conformal-coating, glide the blade along the surface of the PCB a few mm, then lift the blade to pull out a chunk of coating. It is very tender stuff, and does not adhere well to the parts. Repeat as required to create a coating-free crater large enough for the tip of the iron to work in. Any one of the various X-acto blade-types, or equivalent, should work OK.Jeff Carver wrote:...File? Sandpaper? Solvent?remove the conformal-coating material from the terminal you intend to solder to,
You will need some rosin-core solder-wire (0.032" dia), and rosin-flux. Optical magnification may also be of help.... I'm only moderately skilled with a soldering iron, and have no idea what power mine is--
We'll be waiting, tic, tic, ......It'll be a week or so before I'll have time to try it, but I'll report back when I can. ...
She is possibly right! What else could it be?Jeff Carver wrote:...My wife says, maybe it just needs to have a voltmeter riding on its back to work right.
Users browsing this forum: TechGuy and 98 guests
