Beater brush bushing mod
Re: Beater brush bushing mod
Postby vic7767 » March 1st, 2012, 5:58 pm
That is very strange for an XV-11, XV-12 brush assembly. The brush design allows either end of the brush to be installed into the brush holder and accept the belt drive. The cups and bushings are the same on both ends.
The VR-100 on the other hand is designed to be installed only one way.
Postby glnc222 » March 1st, 2012, 8:33 pm
Slight variance in diameter not affecting brass bushings but does bearings. Non-fitting side shaft only .02 mm thicker. Shaft is on the outside of 4mm size tolerance. Can always use them for a belt-side only stiffening of the mount against belt tension for end cup bending and rubbing.
[7/6/13 New Signature Pro model Neato includes ball bearings instead of older bushings]
Postby glnc222 » March 30th, 2012, 4:38 pm
Shaft diameter problem: when one beater shaft proved .01mm too thick for the 4mm bearing, slight grinding the shaft just proved easier: when replacing the rubber end cup with a thinner one outside the geared cap, only the outer end of the shaft needs thinning , so there is room for the bushing to assist spinning the shaft for grinding. Just assuming needs support vs just chucking the whole thing in a drill.
Postby vic7767 » March 30th, 2012, 5:10 pm
I've run into that issue also. Different aluminum assemblies are off just a bit on the metal axle ends. I use some 2000 grit sandpaper and then finish by polishing with a crocus cloth.
Postby glnc222 » March 31st, 2012, 4:21 pm
Kitchen Neato Shaft Grinder and Knife Sharpener in Matching Neato Colors
Kitchen Neato Shaft Grinder and Knife Sharpener, in Matching Neato colors
Postby vic7767 » March 31st, 2012, 5:20 pm
Nice !
Postby glnc222 » March 31st, 2012, 8:54 pm
Bearing friction: With two ball bearings in thinner end cups, flicking the beater (with the belt off) spins it rapidly 4 seconds; scarcely 1/2 second with bushings in standard end cups (they rub inside the gear cap I suspect). Vane drag on the floor probably swamps this.
Users browsing this forum: doublem, mobzd, svobod3 and 293 guests
