Neato rear guide wheel mod
Postby vic7767 » November 30th, 2011, 5:11 pm
Although it is obvious that the plastic used in the construction of the two rear guide wheels will probably last through the standard 1 year warranty offered by most retailers, depending upon the cleaning surface the Neato runs on may speed up that wear and cause failure at or just after the warranty expires.
Here is a mod solution to slow down or even stop that wear and tear on those rear guide wheels. The picture is a .gif type so to view both pictures, click on the image.
Re: Neato rear guide wheel mod
Postby kevinlongisland » November 30th, 2011, 7:08 pm
Cool mod Vic. What did you use to machine the wheel down with?  Due to the shape I can see it being difficult to hold in a lathe.
kevinlongisland
Postby vic7767 » November 30th, 2011, 8:34 pm
I just use a drill press.
Postby Riekopo » August 30th, 2015, 7:33 pm
Can I buy a couple of these for my Botvac 65?
Riekopo
Postby vic7767 » August 30th, 2015, 8:14 pm
I don't offer that mod. Too much effort to make the mod which then makes it an expensive mod.
Postby mfortuna » August 31st, 2015, 7:09 am
My Neato is coming up on 2 years old and the wheels look new, both inside and out.
Users browsing this forum: dboston55, im1kissfan, johnnyh, leonicholson, NoJimForHome, vic7767, wassct and 425 guests
