Neato with a Voltage Monitor
Postby vic7767 » May 26th, 2012, 8:25 pm
You knew it was coming, the Neato also needs an instant voltage display mod just because.
Re: Neato with a Voltage Monitor
Postby glnc222 » May 28th, 2012, 11:56 am
I would like it with a shunt and switch added for selectable vacuum current filter monitoring.
Postby vic7767 » May 28th, 2012, 12:25 pm
I can offer you a meter then you can build your own display choice. Send me an email or PM for price.
Postby glnc222 » May 28th, 2012, 12:33 pm
That Neato picks up interesting debris into the dust bin.
Postby chris-s » May 28th, 2012, 2:51 pm
Is this voltage monitor really useful ?
And why the batteries are in the dust bin place ?
Chris, FRANCE
Neato XV-15 since May 4, 2012
Scooba 230 since May 31, 2012
Braava 380 since May 25, 2013
chris-s
Postby vic7767 » May 28th, 2012, 3:06 pm
chris-s wrote:Is this voltage monitor really useful ?
Of course it's useful if you're interested in battery levels as well as when the Neato decides to return to its charging station. This Neato is in a stage of dis-assembly during the dc meter installation so it was just easier to connect the batteries for demonstration purposes.
Postby glnc222 » May 28th, 2012, 8:47 pm
Neato Robotics posted a comment recently that installing higher capacity Nickel batteries would not increase run time with software used. An interesting question then is whether the converse is true: if the batteries lose capacity, say with age, does the Neato keep running the same time thereby over-running the reserve required to return to dock? The volt meter could reveal all sorts of things.
I wonder just how sophisticated is Neato's calculation of battery reserve for return. Does it take into account the actual capacity of the battery as it ages? Does it see differences in power requirements of return through different environments, carpets and hard floors? Does it adjust requirements on close proximity to the base, where they might be reduced? Does it remember performance of the battery and adjust interpretation of sensor data accordingly? Some of the docking failure problems suggest there might be a few things missing in the present calculations. I would not be surprised to see future improvements. Multi-run recharge docking is a major Neato feature promoted in advertising, after all, much more critical than little details about how precise it maneuvers through corners.
Postby glnc222 » June 5th, 2012, 4:46 pm
Any recommended tools for cutting out the case neatly would be interesting.
Postby vic7767 » June 5th, 2012, 5:36 pm
I outline the shape of the meter with a Sharpie, use a drill bit (1/4") to drill out an opening in all 4 corners inside the outline. Then use a Dremel with a cutting wheel to follow the lines drawn between the 4 holes. Final finish is done using selections from your favorite Needle file set. A lot of final filing and test fittings are required for a tight fit.
Postby glnc222 » June 6th, 2012, 2:56 am
That is an impressive fine skill with the Dremel cutter. Got 1 3/4" saw blade for it might work as well, but better practice on other plastic first. They said works best at high speed. Inexpensive.
Postby mfortuna » June 6th, 2012, 8:06 am
If you have a steady hand an xacto knife is good for carving plastic.
Postby glnc222 » June 10th, 2012, 6:52 pm
How did you attach the meter to the Neato power lines or whatever? Any useful parts?
Postby vic7767 » June 10th, 2012, 7:20 pm
No parts, just a straight splice to the two leads on top of the circuit board.
Postby kevinlongisland » June 11th, 2012, 8:51 pm
Vic, any useful data yet from your voltage monitor? I'm wondering if neato clock reset results from a low battery, and neato claims installing a higher capacity battery won't let it run any longer, does that mean a higher capacity battery might solve the clock reset issue???
kevinlongisland
Postby vic7767 » June 11th, 2012, 9:02 pm
Good questions that will have an answer once the meter modded chassis is installed on a working Neato.
Postby kevinlongisland » June 11th, 2012, 9:46 pm
Has no one successfully installed and run a higher capacity battery yet to see if it resolves the clock reset issue? And possibly RPS error (someone somewhere mentioned RPS error could be linked to low voltage as well)?
kevinlongisland
Postby vic7767 » June 11th, 2012, 9:58 pm
I'm not sure a higher capacity battery is the cure for RPS errors since the Lidar runs on 3.3 or 5 vdc depending on what model you have. I have several different Neato models now that have (so far) not run into RPS errors or clock reset errors at all. Of course this is using just the stock battery sets.
Postby kevinlongisland » June 12th, 2012, 10:16 am
Vic, does your cleaning run require at least one return to base for charging? Have you had any clock reset issues with any of your neatos?
kevinlongisland
Postby vic7767 » June 12th, 2012, 12:22 pm
Yes, both the XV-12 and XV-21 return to their charging base for a top off prior to continuing on their cleaning job.
Postby glnc222 » June 19th, 2012, 11:23 pm
Possible multimeter to mount with innards separated from it's case: ebay listing
http://www.ebay.com/itm/LCD-Digital-19-Range-Pocket-Volt-Ohm-Amp-AC-DC-Multimeter-Probes-USA-Ship-/120935456278?pt=LH_DefaultDomain_0&hash=item1c28509e16
gives the specifications but also cheaper at
both U.S.
Takes 9V maybe supplied by a three 3v coin batteries for compactness.
Perhaps a switch accessed through inside of the dust bin compartment could select between a couple prewired functions.
2.5" wide so display larger than Vic's voltmeter?
What do you think?
Users browsing this forum: aarolar, BCCISProf, DeanR181, Flole, leonicholson, Roomba54, sondejmarek and 417 guests
