New Neato FW Spotted 3.0.17235
Re: New Neato FW Spotted 3.0.17235
Postby kamiraa » December 13th, 2012, 8:03 pm
neato wrote::thumbup:
are YOU the next generation Neato, with the answering questions feature built in ;) haha
kamiraa
Postby neato » December 13th, 2012, 8:26 pm
:techie-typing:
neato
Neato Special Guest
Postby Ralph-G » December 13th, 2012, 8:57 pm
I haven't had time to try to track the source of the message but my best guess it that it was in the system software and was made active by a date sensitive time bomb based on the normal software update schedule.
Ralph-G
Postby djos » December 13th, 2012, 9:08 pm
wow, that is interesting. :)
Current Robot's:
Neato XV-11 w/ VR100 Brush Bar & VR100 Filter
iRobot Scooba 380
Previous Robots:
Evolution Mint 4200
djos
Postby BuBu » December 14th, 2012, 12:00 pm
I also tried to see on my Neato if there was an update... it's answer is a bit confusing to me :lol:
BuBu
Postby kamiraa » December 15th, 2012, 3:08 am
BuBu wrote:I also tried to see on my Neato if there was an update... it's answer is a bit confusing to me :lol:
LOL, I lost it :cheers:
kamiraa
Postby Ralph-G » December 15th, 2012, 11:54 pm
Yes, I guess for those of us who are software adept it is possible to program the screen to show anything that you want, however this is not the case with me. As I said previously I have not connected the Neato to a computer for any purpose whatsoever.
The XV 21 is only 3 weeks old and has the following:
SN 0017176
SW 3.0.17235
LDS V2.6.15295
Board Rev 64
Board SW 17242
Each time the XV 21 is turned on the screen shows that a new software is available and it has to be acknowledge with the OK soft switch before the machine will run.
Mine is a genuine enquiry to see if any one else with a new XV 21 has a similar experience.
Ralph-G
Postby kamiraa » December 16th, 2012, 3:34 am
Ralph-G wrote:Yes, I guess for those of us who are software adept it is possible to program the screen to show anything that you want, however this is not the case with me. As I said previously I have not connected the Neato to a computer for any purpose whatsoever.
SN 0017176
SW 3.0.17235
LDS V2.6.15295
Board Rev 64
Board SW 17242
Ralph I think that basically means that the internal memory had a bit flip, and has become corrupt along the way (it happens)
The only way to fix it, is to rewrite the internal PROM with new code from a validated source (regular upgrade cycle).
I would do the "upgrade" which is just push a good version of code to the internal memory. Correct me if I'm wrong Neato.
kamiraa
Postby denodan » December 16th, 2012, 4:32 am
comp666 wrote:My Neato xv-21 running 3.0.17235 has never successfully docked. It just comes back and stops about a foot away from the docking station. No backup dance. The docking station has 4-5 feet of clearance on each side. This is already my 2nd unit.
Is it safe to downgrade the firmware to 2.6? I heard docking was better in 2.6. Thanks!
Mine is also using 3.0.17235 and so far has always docked perfectly, even from the other side of the house.
denodan
Postby denodan » December 16th, 2012, 4:37 am
I would not downgrade if I where you?
Not only is the XV-21 with firmware 3.0 the newest Neato, it also has some major hardware changes within the mobo. So even if you could load the older firmware into the unit it would not be compatible.
denodan
Postby BuBu » December 16th, 2012, 5:41 am
Basically I just reused your picture and used a graphic program to draw on it. I had big fun making the Neato display a trollface :-D
BuBu
Postby Vetekli » December 16th, 2012, 5:46 am
Any new ETA on the update? :lol:
Vetekli
Postby Ralph-G » December 16th, 2012, 8:06 pm
Hi Guys,
There is nothing wrong with our XV 21. It returns to base for recharge, etc. other than having the software message and sometimes not cleaning all of the rooms in our relatively cluttered house.
I have tried to find a means of contacting Neato Tech support but the web site doesn't help. If anyone knows an email address or similar it would be much appreciated as I don't want to try anything without getting some advice form the manufacturer.
Ralph
posting.php?mode=reply&f=20&t=16275#
Ralph-G
Postby aziesemer2 » December 16th, 2012, 8:37 pm
Ralph-G wrote:Hi Guys,
Ralph
It won't visit a room if you open the door after it do the perimeter. All the times I thought my Neato lost a room was because I forgot I opened the door after that.
aziesemer2
Postby Zerxer » December 16th, 2012, 10:03 pm
Ralph
customercare at neatorobotics dot com
Zerxer
Postby neato » December 16th, 2012, 10:13 pm
Ralph
Sorry you are having trouble with your Neato :(
Please call Neato Customer Care 24/7 at (1-877-296-3286) and describe this issue.
The contact information for Neato is under the About -> Contact Us section of the web site.
neato
Neato Special Guest
Postby Ralph-G » December 16th, 2012, 11:27 pm
Thanks for your help.
For whatever reason each time I Google neatorobitics it takes me to the UK site which has no contact details. I will try the email address that you gave but phoning is not really practical since I in Australia.
Ralph
Ralph-G
Postby neato » December 17th, 2012, 1:18 am
The Neato web site makes a guess at your country. In the upper right hand corner you can select the country/language.
neato
Neato Special Guest
Postby OntheWay » December 17th, 2012, 9:48 am
Prevent Neato from chewing mini-ends of one-side-connected USB cables. It can accidentally suck firmware update alerts. Now we want it capable of draining the firmware's itself too. :lol:
OntheWay
Postby Ralph-G » December 27th, 2012, 6:46 pm
It would seem that the software upgrade message was date related as it no longer appears on start up. But I really do wish that customercare@neatorobotics.com had replied to my email requesting advice.
Ralph
Ralph-G
PreviousNext
Users browsing this forum: No registered users and 97 guests
