Does anybody know exactly what connector the neato battery u
Postby kevinlongisland » July 29th, 2012, 11:49 am
I'm looking for replacement neato battery connectors for experimentation purposes. Need both male and female. Does anyone know what connector they use? Part number or whatever info is needed to order some. Thanks.
kevinlongisland
Re: Does anybody know exactly what connector the neato batte
Postby glnc222 » August 1st, 2012, 12:22 am
[edit] later info from member Gordon: a matching connector is Molex part# 03-06-2042 data sheet http://www.molex.com/pdm_docs/sd/003062042_sd.pdf.
Available at Digi-Key (with low mailing rates for personal orders) and Mouser, for example, in various qualities tin vs gold etc. Neato omits the securing clamp.
More on properties of this connector at http://www.robotreviews.com/chat/viewtopic.php?p=121916#p121916
Also the pins only, from standard D-connectors, can be used in that the female D socket fits inside the receptacle on the battery side of the Neato connector, and stretches to fit over the plug pins on the Neato side. Available in Radio Shack (which does not have the needed size Molex connectors).
For the chassis mounting receptacle* (fit w/pins) Mouser Part# 538-03-06-2042
Use With Male Crimp Terminal Series: 1560 , 1786 , 1854, 1778.
One of the Sn** plated, Series 1560 pin-contact options is here:
http://www.mouser.com/ProductDetail/Molex/03-06-2042/?qs=%2fha2pyFadujBKrt3C86g1NzpsSxhN4t9j%2ft6VpeO4b0%3d
One of the Au** plated, Series 1560 pin-contact options is here:
http://www.mouser.com/Search/ProductDetail.aspx?qs=clwyIdmhKqXyNQ5%2fp50i5g%3d%3d
For the flying battery cable's plug* (fit w/sockets) see 50-29-1758:
http://www.mouser.com/Search/ProductDetail.aspx?qs=g8UYBG4jjiQ%2fyx574ik4Qw%3d%3d
Use With Female Crimp Terminal Series: 1561, 4559, 4529, 2190, 2189, 1787, 1855.
One of the Sn** plated, Series 1560 socket-contact options is here:
http://www.mouser.com/ProductDetail/Molex/02-06-1103?qs=sGAEpiMZZMuzXLcWrSfMr4AImWoNFp%252b4f0cLcHvCAeY%3d
One of the Au** plated Series 1561 socket-contact options is here:
http://www.mouser.com/ProductDetail/Molex/02-06-5103/?qs=sGAEpiMZZMuzXLcWrSfMr5BIPaVsZl7YHzArM5djr7A%3d
Not made for frequent plugging: viewtopic.php?p=121922#p121922
[edit]removal tool
The removal tool is expensive. I found drilling into the open end with a 3/32" twist drill bit removes them without damaging the shell.
[edit]Botvac connector different: 3mm Pitch 6 pin AMP TE Micro-Mate-N-Lok 1445022-6
Distributors Digi-Key part no. A30262-ND, Mouser 571-14450226
Extractor TE 305183
Users browsing this forum: dianekeller411, im1kissfan, joanquro, johnnyh and 384 guests
