vic7767 wrote:As posted by Neato, the XV-21 firmware not only monitors the battery voltage but also the calculated battery capacity to decide when to begin the visit to the charging base. I would suspect that once the XV-21 shuts down the brush motor and if at that point the drive motors were also shut down, you might see 14.2 vdc.
soonai wrote:i think you have a charger problem. i have just had my neato replaced because the neato refused to recharge. my husband opened the bot and the 4 pin had one faulty pin. i think you will have to contact neato. regards
vic7767 wrote:This thread has veered away from the posted topic, here's my attempt at getting back on track. As I reported in another thread my FW 3.0 XV-21 was experiencing short run times (20 minutes) and returning to its dock. I hacked the twin battery packs and replace the cells with 4/3 tabbed 4500 mAH cells. First new run with the hacked packs resulted in a 70 minute run time with a beginning voltage of 16.4 vdc. The reserve battery voltage with the brush running was 13.4 vdc and when the brush motor was shut down the voltage returned to 14.1 vdc on its way to the dock.
neato special guest wrote:...Some revision 3.0 Neatos had batteries that did not have full capacity...
neato customer care wrote:There was definitely not a bad batch of batteries or any bad robots.
android wrote:Hi,
My neato is bought in the US, but I have since bring it outside the US, will neato be able to send me replacement batteries outside the us since I am having low run time of less then 30mins ?
neato wrote:Neato customer support has recently noticed an increase in under-capacity batteries. Some revision 3.0 Neatos had batteries that did not have full capacity.
If a new Neato has a run time less than 40 minutes, customers should contact our Customer Care team 24/7 at (1-877-296-3286) and describe the issue.
denodan wrote:Well if you put new batteries in Neato, then you have to tell it they are new, else the life will be shorter, so suspect the same will be with a new Neato, tell it the battery is new. seems you guys maybe not doing this tip
Users browsing this forum: vic7767 and 78 guests
