by JakobRosenberg » December 16th, 2012, 2:50 pm
Hi, does anyone know if it is possible to repair or order a new PCB for the charging base for Neato XV 25. The green light in the power adapter starts flashing whenever I plug it in to the charging base.
- Attachments
JakobRosenberg
by vic7767 » December 16th, 2012, 3:07 pm
Presently no-one has identified what component has failed in the charging base circuit board. The only option is to obtain a replacement charging base. Of course if under a warranty you have a second option.
- Robot Master
by JakobRosenberg » December 17th, 2012, 4:19 pm
Hi Vic and thank you for your reply. Am I correct to assume that this is a somewhat common problem?
EDIT: Do you know if the XV-11/15 base is compatible with XV-25?
JakobRosenberg
by vic7767 » December 17th, 2012, 4:30 pm
This is NOT a common issue. I suspect that the XV-11 and XV-15 power supplies are compatible but I also suspect that the higher models like the XV-21 and XV-25 use a different power supply.
- Robot Master
Users browsing this forum: 911medic, Brett, Flole, im1kissfan, johnnyh, KeldBroe, lanchez, loisebond23, magura, vic7767 and 395 guests
