SharonHak wrote:hi
I just got my new neato xv-21 yesterday.
I put the station in one of five rooms in my apartment.
The Neato was charged fully, i set the time and pushed the start button.
The Neato started to clean immediatly.
As the Neato finished to clean the room it went back to the station (message "finished clean") and didnt exit the room to clean the other rooms.
I tried 3 times and all of them were the same (the Neato cleaned only the room where the station is and didnt go out from the room for cleaning the other rooms).
Can anyone help me with this situation??
What i need to do??
Thanks.
OntheWay wrote:SharonHak wrote:hi
What i need to do??
Thanks.
Hi, primary reason for such a behaviour is keeping the door of first room closed, during the initial scan (neato moves out of docking station and turns left and right, so, looks around). If you open or close doors, or move larger (wider) furnitures during the operation, depending on the changes you applied, it may skip open-doors, or try to open (!) closed doors, it may start thinking of being somewhere else of the house, due to spoiled house map in memory, resulting some weird shaking or wall kicking behaviours.
Best move is to adjust doors and furnitures before running the unit, and leave the house as is. I really wish it could be able to detect inexistence(movement) of larger objects and clean these spaces, but this only causes problems.
Enough serious stuff, now, according to insider information(!) this problem will be solved with 3D scanner version of Neato, a.k.a. Neato 3D-11, the first cloud-enabled vacuum robot that stores current and main shape and problem corners info in the cloud, allows the Neato to clean your house much more efficiently (a small monthly fee applies here to store your point cloud data, in the cloud)
OntheWay wrote:Instead of resetting, you may try changing the place of docking station first, preferably in the same room. If problem persists, move to next stage, put the station into another room.
edit. When you run neato, dont stay in front of door to watch, in order to allow it discover the exit.
Users browsing this forum: No registered users and 112 guests
