Android app
Android app
Postby oblio » March 3rd, 2013, 6:36 pm
oblio
Re: Android app
Postby c.mueller » March 4th, 2013, 9:33 am
Release Date: 03.03.2013
So i would say: Yes.
It is no secret the Neato can be controlled via USB. So Alexander Zakharyan has written an App to do so... :thanks:
neato XV-15
c.mueller
Re: Android app
Postby Yemanja » March 5th, 2013, 2:27 am
Great!!! But now wireless?
Yemanja
Re: Android app
Postby vic7767 » March 5th, 2013, 11:13 am
No, it requires a tether cable.
Re: Android app
Postby crowone » March 6th, 2013, 11:26 am
Can I use 2 usb cables with a coupler? Female-Female
crowone
Re: Android app
Postby vic7767 » March 6th, 2013, 1:25 pm
Good question..... Try it and let us know if it works.
Re: Android app
Postby Jeff_K » March 10th, 2013, 6:40 pm
Has anyone gotten this app to install (never mind work)?
I get the following error when trying to install:
"There is a problem parsing the package."
Settings/Applications/Unknown sources is checked (to allow unknown sources), but it doesn't help.
01011001011001010110000100100000010011100110010101100001011101000110111100100001
Jeff_K
Re: Android app
Postby crowone » March 11th, 2013, 9:44 am
Yes, I install on a Samsung Note. (android 4.03)
just waiting for a connector. :)
crowone
Re: Android app
Postby Gibby » June 7th, 2013, 12:10 pm
I am still waiting on my micro to usb connector, but I saw in the review it talks about Bluetooth.... I take it there is a mod required to enable bluetooth on the Neato?
Gibby
Re: Android app
Postby vic7767 » June 7th, 2013, 2:38 pm
There is a mod that can be performed on the early XV-11s that Neato sold to the public. It requires disassembly and access to the main circuit board to add a 6 pin header and bluetooth module from Sparkfun.com. Then you will have bluetooth in your Neato.
Sad to say be all later models that Neato now offers do not contain the modified circuit board thus no more bluetooth.
Re: Android app
Postby a4refillpad » June 7th, 2013, 9:06 pm
vic7767 wrote:There is a mod that can be performed on the early XV-11s that Neato sold to the public
rev 113 or even older?
current bots: Samsung SR8980, Vorwerk VR-100, Roomba 770, Neato XV-25, Hauzen VC-RE70V, Evo Mint 2, Karcher RC3000, Robomow RL350 (lawnmower)
a4refillpad
Re: Android app
Postby vic7767 » June 7th, 2013, 10:21 pm
Rev 113 and possibly older. Neato went after hackers with their early models big time.
Re: Android app
Postby mfortuna » June 8th, 2013, 8:09 am
vic7767 wrote:Rev 113 and possibly older. Neato went after hackers with their early models big time.
Was it a case of going after hackers or just having provisions for debugging?
It would be a delicate soldering job but a bluetooth module could be added. Even though the header is gone, the signals are probably still there.
Re: Android app
Postby a4refillpad » June 8th, 2013, 2:57 pm
Would be fantastic to be able to remotely launch the neato from a phone (maybe via Bluetooth hosted on a PC). Many scenarios like unexpected guests arriving or kicking it off because you are out longer than expected etc....
a4refillpad
Re: Android app
Postby glnc222 » June 8th, 2013, 3:23 pm
Thanks to your reference to the Microsoft utility for controlling the USB port, a method of remotely launching Neato was posted in Mods for Utility http://www.robotreviews.com/chat/viewtopic.php?f=20&t=16475
Requires cable from PC or other device to the charger.
Re: Android app
Postby vic7767 » June 8th, 2013, 4:25 pm
mfortuna wrote:Was it a case of going after hackers or just having provisions for debugging?
Pretty sure it was built for hackers since the USB port provided a way to send commands for debugging.
Re: Android app
Postby a4refillpad » June 8th, 2013, 5:37 pm
Is there a link to a thread that describes the procedure? Soldering a USB header should be straightforward if I have the details and the right PCB.
a4refillpad
Re: Android app
Postby vic7767 » June 8th, 2013, 6:23 pm
The USB to mini USB cable that is used for upgrading the firmware can also be used to send commands to the Neato via the PC and a terminal program like Hyperterm or Realterm.
The header statement was mentioned when adding the 6 pin bluetooth device to the rev 113 mainboard that included a 6 pin punching and foil trace to the Tx, Rx ports of the MCU.
I have opened a rev 64 Neato and observed that the 6 pin punching for installing a bluetooth device has been completely removed. I don't presently have a pinout of the MCU used on the main board to see if there is access to the TTL level Tx, Rx ports.
Re: Android app
Postby glnc222 » June 8th, 2013, 7:01 pm
Re: Android app
Postby glnc222 » June 9th, 2013, 3:11 am
Pretty sure it [main board serial header] was built for hackers since the USB port provided a way to send commands for debugging.
It could have been a legacy of development where all the pieces of a USB interface, software and specialized parts for the final product, were not initially available and the serial port was easier and faster to build and use for development work. From what I see, somewhat cumbersome high capacity equipment is used as USB hosts, from the purpose of that standard, for disk drives and the like, which also makes radio connection to Neato's usb not so easy, if they needed that. Initially the USB section just got added onto an existing board design left to be refined in later revisions, which finally happened. They might have had some test equipment left over as well, which later got revised to USB. A sort of leap frog pattern of changes, add something first, then later drop something. Maybe it is to run both things for a while until the new stuff is checked out more, like new accounting systems run in parallel with old, before committing to the advance.
Users browsing this forum: boppen, neat99, ohiyo777, TechGuy and 87 guests
