neato xv-21 serial port wifi
Postby undertoe » May 15th, 2014, 3:41 pm
New to the boards, but i am investigating adding wifi webserver to the neato. I know there are a couple threads on the board about it and i was reading through them and i know the serial port is missing on this version. What i did notice on newer XV-11 the pins are missing but the spot where the pins connect are still there. Assuming i could just solder in a connector and get a working serial connection. My question is since i never took my XV-21 apart is this the same case with the board inside there? Any help would be appreciated. THanks!
undertoe
Re: neato xv-21 serial port wifi
Postby vic7767 » May 15th, 2014, 3:48 pm
It will depend upon what main board is installed in your Neato. If it's a rev 113 then it's possible. If you have a rev 64 then you're outta luck.
Postby undertoe » May 15th, 2014, 6:14 pm
vic do you happen to have any mb pictures?
undertoe
Postby vic7767 » May 15th, 2014, 8:19 pm
Here's a couple, the first will be the older rev 113 then the rev 64.
Postby undertoe » May 23rd, 2014, 11:34 am
I am assuming the USB port is just a serial to USB adapter so before it I'm just going to try to splice in. Anyone try this yet?
undertoe
Postby vic7767 » May 23rd, 2014, 12:11 pm
Have you connected to your Neato using the NeatoRobotics driver and a USB-A to mini USB cable yet ? Start with that configuration and then see if you want to try and add a WiFi interface.
Postby undertoe » May 23rd, 2014, 8:57 pm
Yea I actually had it working with a RasPi I got a Spark that has a serial interface and I want to work on getting that running cause it smaller and way less power
undertoe
Having a hell of a time getting the top cover off the xv-21
undertoe
Postby undertoe » May 23rd, 2014, 9:02 pm
Have any links to take one apart. I have all the screws i can see off. Seems to be catching in the middle
undertoe
Postby undertoe » May 23rd, 2014, 9:04 pm
undertoe
Postby vic7767 » May 23rd, 2014, 9:22 pm
In your first picture there are two small patches of white looking tape. If you poke a hole in them you will see two additional screws that must be removed in order to remove the top.
Postby vic7767 » May 23rd, 2014, 9:35 pm
Let us know of your progress, many will be interested, including myself
Postby undertoe » May 23rd, 2014, 9:46 pm
Your the man! Thanks! Any thoughts to my comment above about tracing the USB port back to where it does the serial to usb conversion
undertoe
Postby undertoe » May 23rd, 2014, 9:54 pm
Here is where it goes back to.
which makes sense http://www.nxp.com/products/microcontro ... ET180.html
undertoe
Postby undertoe » May 23rd, 2014, 10:05 pm
Here is TX & RX on the Pin layout. Thing that sucks is my soldering skills aren't that good to get something on there :)
Pin Diagram
2014-05-23 22_01_37-www.nxp.com_documents_data_sheet_LPC3141_43.jpg (24.64 KiB) Viewed 12558 times
undertoe
Postby vic7767 » May 23rd, 2014, 10:30 pm
You've done some good sleuthing work on that chip. I haven't tried to trace out the UART leads to the USB termination. Maybe others will chip in here with clues.
Postby undertoe » May 23rd, 2014, 10:48 pm
Yea bummer is its an ARM chip and its a crap shoot if they actually have that functionality turned on... I think for now i am going to throw it back together. I am gonna start messing around with the spark and see if it can connect it via usb / serial and throw commands at it. If i can figure out how to do that it will make this mod a lot more user friendly, which is originally what i was after.
undertoe
Postby vic7767 » May 23rd, 2014, 11:16 pm
Got any info on the Spark ?
EDIT: Here's info about the Spark WiFi: https://www.spark.io/
Postby undertoe » May 24th, 2014, 12:29 pm
Oh yea I already have an active thread going. I have a working proto with a ras pi and apache. Works with the clean command but has to reset the PCI bus in order to get the neato to think it's disconnected. However I was thinking with the spark I could do that with a small relay setup triggered by the spark. Would love to make this as easy and user friendly as possible I. The end so others can do it.
undertoe
Postby mfortuna » May 24th, 2014, 3:06 pm
undertoe wrote:Your the man! Thanks! Any thoughts to my comment above about tracing the USB port back to where it does the serial to usb conversion
The USB to serial conversion is done on the ARM, it has a USB phy built in. Most likely it is in device mode so if you could bridge a USB master to a wifi module you may be able to get it to work.
My beaglebone and raspberry pi both have USB masters. The pi has two so you could plug in a USB to neato cable and a wifi dongle without a USB hub.
http://www.makershed.com/WiFi_802_11b_g ... 5V0H7w_wcB
Of course you have to write/find software that sends data to/from WIFI and USB.
Users browsing this forum: im1kissfan, jdong, leonicholson, Miles267, vicdeng and 153 guests
