Wake Neato up from dead mode
Re: Wake Neato up from dead mode
Postby dsstrainer » April 14th, 2016, 10:34 am
I just performed a successful C10-ectomy on my XV-21 and we are back in business :)
It was about a 2 hour process... and yes I have 2 extra screws left over because I couldn't remember where they went... but there were a LOT of unnecessary screws in that pig to begin with so I think it's ok. The patient is in recovery but I gave it a run late last night for about 2 mins and it seems to be working fine.
:cheers:
dsstrainer
Postby Brett » April 15th, 2016, 8:31 am
dsstrainer wrote:... and yes I have 2 extra screws left over ...
Those two under the dust bin?
Postby grapedrink » April 21st, 2016, 10:17 pm
dsstrainer wrote:I just performed a successful C10-ectomy on my XV-21 and we are back in business :)
:cheers:
Don't hold your breath. It will begin developing issues soon.
Like you, I thought the C10 replacement would solve issues with the Vac completely but it doesn't.
What happens with mine is every time I run, I start the cleaning run, and after 5 minutes, the vac reports low battery. Then I have to carry it and put it back the charging dock, after it charges for about 10 minutes only then does it run for about 15-30 minutes.
grapedrink
Postby vic7767 » April 21st, 2016, 11:00 pm
grapedrink wrote:Don't hold your breath. It will begin developing issues soon.
How old are the packs in your Neato?
Postby glnc222 » April 21st, 2016, 11:10 pm
Short charging time and short run time are symptoms of defective batteries which do not hold a charge, have lost capacity. The small capacity is quickly filled and drained. The charger detects normal end of charging condition, battery filled, but not much charge has been added.
The end of charging is signaled by heating in NiMh batteries.
Defective or worn batteries will show voltages similar to good ones and just exhibit low capacity.
Of course, the charging process can also be at fault. Over USB there is a Fuel Gauge per cent which should show close to 100 when finished charging, but I am not sure how affected by worn batteries. The charging current can be observed over USB etc. There have been cases of defective docks.
It is also possible the sensor circuits for monitoring the battery are not working properly, in which case the system board would need replacement.
Besides C10 some users have replaced all the electrolytic capacitors. C10 was involved in power supply to the cpu and memory, not starting up properly. A unique situation occurred where the processor saw an empty memory starting too slow, and went into firmware update mode.
Postby Siggy169 » April 28th, 2016, 6:33 am
I can not believe that Neato havent yet fixed this issue.
I had an XV21 that eventually died 1 week after the warranty expired, and by died I mean it would no longer charge, just sit on the dock flashing its green light at me and doing nothing. New batteries extended its life by a few months and the USB trick by a few weeks, after that nothing.
I read others had issues but I thought I just had a lemon - as when it worked it was absolutely fantastic and my wife loved it.
3 months after it dies I decided to get another one - I know I am stupid - a Botvac 85 - I seriously thought they would have solved this issue by now.
BUT NO - if it doesnt make it back to base for any reason, it shuts down and dies. This is only 4 months old. I have been doing the power off and leave off the base for 15 mins and then power on and oput back on base, and that has been working for the last 2 months.
Now - nothing - red flashing led, and then green solid LED and then stays green but doesnt charge or turn on again.
They seriously need to look at their software and pit some tolerance into it so that the robot doesnt just die if it cant get back to base /end rant
Does anyone know how to revive a botvac 85 please?
Siggy169
Postby JEfromCanada » April 28th, 2016, 8:35 am
If your unit is only a few months old, you should get it replaced under warranty rather than trying to fix it.
Postby Siggy169 » April 29th, 2016, 4:42 am
Thanks,
That's my next step - but it is a hassle!
Siggy169
Postby shirgal » May 9th, 2016, 6:07 am
Siggy169
To revive your D85 try holding the start for 15sec or more until no light is visible,
Than click start again and watch if it revives to life.
Let me know how it went.
shirgal
Postby korna » January 22nd, 2017, 7:38 am
On my XV-25 I had the constant green led and no display problem. So I replaced the C10 capacitor and all others of the same type. The XV-25 starts up however, I now get error "battery issue 0002".
Any suggestions on how to diagnose the problem?
korna
Postby glnc222 » January 22nd, 2017, 1:46 pm
Power it on the dock if necessary and read battery conditions over USB (with Neato Control Program etc.).
We do not have definitions of the different battery error numbers, but a search of the forum shows a lot of them are due to depressed pins in the battery Molex connector. Press on the pins (both battery and Neato sides) with a screw driver to see if firmly fastened. Depressed ones can sometimes be fixed just pulling up with pliers.
Neato measures battery voltage, current, and temperature shown over USB, and responds to anomalies preventing normal operation with error messages. The battery switch on some units can also be faulty.
One user reported an interesting procedure of booting the computer on the dock with the battery disconnected and then connecting the battery after the cpu is running.
Postby glnc222 » February 3rd, 2017, 11:53 pm
Repair Videos
Several Youtube videos show this repair, some with dubious soldering technique:
https://www.youtube.com/watch?v=Rw4JVeu5pxs
https://www.youtube.com/watch?v=pHdOYKNjcV0
https://www.youtube.com/watch?v=WR7yx-E1Y14
The electrolytic capacitor is polarized, observe the orientation and markings + and -. To remove the capacitor apply iron to the back side on one pin while inserting a knife blade under and prying up. Alternate between pins to lift out pins a little at a time. User sucking tool to remove solder from hole, applying iron to back and sucker to the front.
Also once lifted slightly the pins can be clipped and the remainder pulled with pliers while heating.
Postby gillspie » February 23rd, 2018, 7:09 pm
I have the same thing with a XV-11. I think it is the usb driver but I don't know what to do to fix it.
gillspie
Postby neato-fan » February 28th, 2018, 10:09 pm
Just replaced C10 in my older XV-21 with Rubicon CAP ALUM 120uF 20% 35V RADIAL (35YXG120MEFC8X11.5 http://d.digikey.com/THpSi000p00emXO00N1J7K0).
The old one had 197nF left from 100uF, so basically no capacity left. There is no need for cap with higher capacity as it increases the size and could make fit issues.
No more occasional dim light :D . I did not bother with the rest of the capacitors (all the same capacity and voltage rating), as replacement is kind of difficult due to desoldering complications.
Just one advise, be careful with logic board and laser mounting screws, make sure they are pre-threaded into original threads, otherwise the plastic base becomes very brittle over time and can crack easy when forcing the screw to re-thread the hole.
Also, I found - it is way easier to connect top cover wires and flip vac upside down, then lift lower half at the bumper side slightly and install side sensor arms into bumper (on the bottom and push them into the bumper), then lower the bottom half, it will stuck on the tips of the sensor springs, now just take flat screwdriver and compress every switch spring slightly and push it down - the spring will snap into place, then just secure bumper with deep hole screws. Otherwise, it was taking way to long to get all arms to align and they are quite loose when resting on the bottom half.
Ah, and when you power it back, do not forget to set clock and most important - go to "Support" and select "New Battery" to make sure it is recalibrated after power loss.
Good Luck!
neato-fan
Postby eplur » March 29th, 2018, 9:44 pm
Thank you so much n00. That fixed it. i didn't get the display at the beginning but connecting to laptop with neato also connected to power worked.
Thanks a million.
eplur
Users browsing this forum: 911medic, derekobrian, gregj, jdong, Miles267, someoneclever, symbol, teokakav and 360 guests
