Neato XV vs Botvac comparison, corners and walls (blade bru
Postby chris-s » October 1st, 2014, 2:49 pm
Hi all !
My new Botvac arrived yesterday at home, replacing an XV-15 8)
This angle was vaccumed once a week by my XV, but never with a regular vaccum during last 2 years.
Do you think that rotative side brush is useless on carpet ?
I don't ;)
Enjoy !
Chris, FRANCE
Neato XV-15 since May 4, 2012
Scooba 230 since May 31, 2012
Braava 380 since May 25, 2013
chris-s
Re: Neato XV vs Botvac comparison, corners and walls (blade
Postby glnc222 » October 2nd, 2014, 2:01 am
Magnifique!
The newest Vorwerk VR200 has the brush in front of the corner, so might get that last bit left. Not available outside Europe or Vorwerk's limited distribution network. And several times the cost of Neato's.
Postby Wing Nut » October 2nd, 2014, 4:19 am
It does an impressive near-edge clean even without the side brush ... and on carpet!
Wing Nut
Postby chris-s » October 2nd, 2014, 10:33 am
glnc222 wrote:The newest Vorwerk VR200 has the brush in front of the corner, so might get that last bit left. Not available outside Europe or Vorwerk's limited distribution network. And several times the cost of Neato's.
Yes, the VR200 will have better corner covering, but less efficiency around furniture leg.
Chris, FRANCE
chris-s
Postby glnc222 » October 2nd, 2014, 2:03 pm
I should have asked how do we know it is the side brush instead of the enhanced main brush closer to the wall on the BotVac, given carpet is involved?
Postby JEfromCanada » October 2nd, 2014, 2:57 pm
glnc222 wrote:I should have asked how do we know it is the side brush instead of the enhanced main brush closer to the wall on the BotVac, given carpet is involved?
The video showed two passes - first without the side brush and then with the side brush. It seemed clear that the pass without the side brush got closer to the wall than the XV series, but still not all the way to the wall. The subsequent pass with the side brush clearly covered the small gap between the vacuum's built-in brush and the wall.
Postby chris-s » October 2nd, 2014, 3:02 pm
Exactly JEfromCanada :)
Chris, FRANCE
chris-s
Postby neat99 » October 11th, 2014, 3:31 pm
Chris-s, wow. Thanks for sharing. Please continue to keep us posted on how the botvac performs.
neat99
Postby glnc222 » November 8th, 2014, 10:52 pm
Another Test, Different Carpet & Material
Filter grind Columbian coffee, loop pile carpet, Neato Botvac
Hard Floor Before
Hard Floor After
I have previously explained backscatter as result of brush shape and position behind the intake. Gotten by front next run.
Carpet Before
Carpet After
(a broom cannot remove this leftover, takes strong suction)
Bin from hard floor and carpet
Side brush effectiveness in the hands of your interior decorator
Postby Wing Nut » November 9th, 2014, 5:20 am
glnc222 wrote:Another Test, Different Carpet & Material
As a coffee fan, I'm not sure I approve of this test and the rather upsetting images. Next time could you perhaps try sawdust or dried parsley flakes? :)
Wing Nut
Postby mfortuna » November 9th, 2014, 8:50 am
What's wrong with parsley! :)
Postby glnc222 » November 9th, 2014, 3:09 pm
No bother, was only Decaf.
A mix of parsley, sage, rosemary and thyme. Buy bots at Scarborough fair.
Coffee shows well in photos. Maybe Tea, Earl Gray, not hot.
Also concern the delicate side brush gets messed up running on grabbing carpet.
Users browsing this forum: dianekeller411, im1kissfan, joanquro, johnnyh and 380 guests
