Neato Botvac 80 very stupid - having issues
Re: Neato Botvac 80 very stupid - having issues
Postby neato-fan » April 4th, 2018, 11:14 pm
Thanks for the info. I think disassembly is the easiest way to rebuilt those switches. With equivalent of Exacto knife cut the plastic pins flash with cover, pull on plunger, it will open. The issue is small crystals forming in the center. It is easy to remove just wipe. I used electric cleaner/grease to clean with ear tips and then wiped it with some watchmaker thing called "rodico" (very inexpensive Egyptian thing) - it would remove oil and any fiber contamination. Then just reassembled (the cover will snap on pins and will be held closed) and then used tiny quick set epoxy dubs to secure cover on top of the cut off plastic pins. Good Luck!
neato-fan
Postby glnc222 » April 5th, 2018, 7:04 pm
Re multi-pin desoldering with Low Temp solder, TechGuy prior post http://www.robotreviews.com/chat/viewtopic.php?p=139518#p139518
I wonder how a replacement for the removed IC shown in the video would be soldered in, with all those tiny pins. Removal seems easier. Can this be done manually? It is all done with solder paste and an oven in factory, right?
Users browsing this forum: jdong, txenakis, vic7767 and 401 guests
