GUIDE: How to update Neato XV Series using Vorwek Updater
Re: GUIDE: How to update Neato XV Series using Vorwek Update
Postby thomas » January 14th, 2017, 1:05 pm
thanks for your work.
updated an xv11 from 2.4 to 3.2 with the vorwerk tool
But needed an old lenovo laptop with intel chipset to made the usb connection work.
let the testint begin.. :D
thomas
Postby cdma » January 28th, 2017, 4:05 pm
So I assume that If I have this version that I cannot upgrade?
SW 3.1.17844
LDS V2.6.15295
Board Rev 64
Board SW 17624
cdma
Postby glnc222 » January 28th, 2017, 4:30 pm
There are separate software versions for the old Rev113 Cruz system board and the newer Rev64 Binky board which you have (cpu hardware revision). Files for the Rev64 are in thread http://www.robotreviews.com/chat/viewtopic.php?p=134696#p134696
There is not much additional beyond v3.1 which added the "corner clever" maneuver for better cleaning in corners.
v3.4 is the last update for XV models; no updates have been made to Botvac's without WiFi. Like driver software in PC's, there is little need to update unless there is a specific problem to address. Flashing the firmware entails risks of errors damaging the system irrevocably. Flashing is performed by the robot itself, which has to be intact to perform any such operation -- catch 22 so to speak.
The WiFi models can use more frequent updates just for the complications of WiFi itself, tying the robot to a separate technology with changes over time in standards and methods, not to mention incomplete software to begin with.
Postby cdma » January 28th, 2017, 8:25 pm
So what you are saying is that there is no need to update. I am not having any problems but I really dont see what the difference is between 3.1 and 3.4. Is there something that shows me the improvements?
cdma
Postby glnc222 » January 31st, 2017, 8:21 pm
Neato Robotics makes some comments on the website when firmware is released but I forget where. Anyway their remarks are vague and mention "improved power management" for "better battery life" and such things without specifics. New features like the "corner clever" behavior get more coverage. I recall one thing with v3.4 was possibly addressing a peculiar behavior where the robot would stop just in front of the charger without docking. This could be due to requiring a reserve to withdraw from the dock in case of a bad connection, with inconsistent standards for measuring the reserve. It was thought they increased the reserve and slightly reduced the run time to fix this. Some revisions can just be for tweaks no one notices.
Before discontinuing internet updates the company advised updates should not be performed without a specific repair issue to address. There were a lot of problems with their internet update procedure compared to Vorwerk's, and in contrast to products such as printers. Their purpose is not clear given how it is also common not to supply free software additions to products indefinitely, and selling new hardware to cover its cost.
Postby Geppo » May 21st, 2017, 9:16 am
I'm going to upgrade my XV-11 Board Rev. 113 (SW 2.6.15840 LDS v2.615295) to a newer firmware release using the Djos procedure. Before upgrading I would like to know if the VR100 updater allows also to downgrade to a previuous firmware release, in the eventuality something does not work as desired in the new firmware. Reading this thread I understood that upgrading has no effect on battery charging alghorithm. I just replaced the dead original batteries with a lithium power batteries for the XV Series, so I would like to receive a confirmation before proceeding. Thank you in advance.
Geppo
Postby famewolf » July 27th, 2017, 11:53 am
Really appreciate these instructions. Got my old XV-11 updated to 3.2. I also have an XV-21 which is REV 64/Binky. Can anyone point to where I can direct download the latest for it? Neato apparently "lost" all my info at some point and now wants me to re-register my device before I'm allowed to download the firmware updates.
@geppo If it helps I also had the lithium batteries in my XV-11 and the upgrade went smoothly.
*update* Please disregard my question about links for REV 64. I see the link above in the thread that I missed previously.
famewolf
Postby kallepult » February 21st, 2018, 5:12 pm
Hi all,
I am trying to update my XV-15 from version 2.7 to 3.1/3.2 following all steps in the very nice guide, but when attempting the update using the Vorwerk Updater I get the following error in step 3/5:
"No connection possible! The most recently loaded configuration will continue to be used
Device information
Model VR100
Version 2,7,16621
Serial number: WTD39611DD,0026287,P
Update
Version: 2,7,16621
Info: No release notes available
Status: No connection possible"
Is the issue with the connection a problem related to the USB connection to the robot, the internet connection to the Kobold website or access to firmware on my computer?
Thanks in advance!
Best regards,
Kasper
kallepult
Postby kallepult » February 21st, 2018, 5:35 pm
I solved the issue by manually downloading the version 3.1 firmware from the Kobold website, specifying the downloaded zip file in the Kobold update software:
https://kobold.vorwerk.co.uk/service/se ... tes-vr100/
Cheers,
Kasper
kallepult
Postby glnc222 » February 22nd, 2018, 1:46 pm
The updater program sends text commands over USB documented in the manual post top of forum. The USB connection can be tested with a terminal emulator program such as hyperterminal, Realterm, Putty etc. The bot echos character by character immediately showing the connection. e.g. command GetVersion shows the bot's firmware status and configuration.
I thought you must issue SetConfig commands to convert XV models to Vorwerk for the Vorwerk updater, and then back to XV configuration afterwards, but have not performed this procedure myself. The difference would mainly be enabling the side brush on Vorwerk's missing on XV's, if that makes any difference. The Vorwerk updater will also want to see a Vorwerk configuration when updating to verify proper match of firmware for the system board.
Users browsing this forum: 911medic, derekobrian, gregj, jdong, Miles267, someoneclever, symbol, teokakav and 355 guests
