Page 1 of 2
POLL: How long has YOUR Neato lasted?
PostPosted: February 12th, 2016, 9:02 am
by robocleaner
Neatos suffered a flurry of assorted failures when they were first introduced. Those problems did seem to get resolved over time. Now the Neato Brand has been around for some time, some new, longer term reliability issues seem to be coming to light. I thought it may be interesting to see how reliable Neatos really are...
This Poll applies to any model Neato... if you've bought ANY model of Neato XV or Neato Botvac, select ONE of the above options that applies to the FIRST Neato you bought (not any warranty replacement, since a few contributors here on this forum are on their third, fourth and fifth warranty replacements before they got a "good" one).
So, the question is this:
HOW LONG DID YOUR FIRST NEATO LAST BEFORE IT NEEDED FIXING?
I suppose we should exclude battery replacements IF they occurred AFTER 6 months since that would count as "fair wear and tear" and no company warranties batteries beyond that term.
If you haven't had a failure, check one of the last two boxes. I picked 3 years as 3 years of trouble-free use I think should be a reasonable expectation from a product of this value.
I guess in the interests of fairness, a similar poll should be set-up for Roombas, Samsungs, LG Robokings, Karcher as well?
Re: POLL: How long has YOUR Neato lasted?
PostPosted: February 12th, 2016, 10:44 am
by Fillimerica
Botvac BV85. Side brush (belt) broke within 6-months. Self repaired due to Neato's horrible warranty procedure.
Same unit lasted to the 7 month mark when the gearing inside the left drive wheel started slipping and the bot was doing doughnuts instead of cleaning. No self repair for that problem.
Thank you BBB, replaced with a brand new D85 a week ago. We'll see if that one lasts.
PostPosted: February 12th, 2016, 8:10 pm
by mfortuna
I can't vote because my Neato has not had a defect (battery excluded) but is less than 3 years old.
PostPosted: February 13th, 2016, 9:07 am
by robocleaner
Oops... good point Mike. I'll try editing the poll to add a new field for "delighted" Neato owners and see what happens...
Oh heck... that lost all the votes!
PostPosted: February 14th, 2016, 5:13 am
by 595
Edit my vote. Should of been lasted 3 years and still working perfectly (XV11)
PostPosted: February 14th, 2016, 12:45 pm
by Toodle
My XV21 failed within 6 months. The lidar failed. I received a refurbished unit from Neato that looked like it had led a rough life. It managed to outlast the warranty period but has now failed too. When the XV21 ran, it cleaned well. We have a fairly small home, cleaning 4 times a week. I wish it lasted longer.
PostPosted: February 15th, 2016, 1:02 pm
by jdong
My BotVac65 eventually died a quiet death about a year and 2 months after I purchased it :(.
Dug it out of a closet after months of not using it, and was setting up a test course, and realized it was acting lost and eventually said PLEASE CLEAR MY PATH. Did not see any visible debris in the turret.
Thank you Costco for taking it back. The manufacturer was not very sympathetic because the warranty had just run out.
PostPosted: February 15th, 2016, 1:27 pm
by JEfromCanada
jdong wrote:Dug it out of a closet after months of not using it
Costco was good to take it back. But after that much time in the closet, the battery would have been under powered, leading to errors on top of what might already have been there.
PostPosted: February 15th, 2016, 10:03 pm
by holmes4
I voted ">3 years and no problems", but I then realized that wasn't true. The first XV-11 I bought, soon after introduction, was defective right away. Neato replaced it and that one has been fine ever since (other than battery replacement.)
PostPosted: February 16th, 2016, 9:11 am
by frenchie
First one didn't last long. I've had the second one since then (2 years), no issues, runs 3 times a week. The only time it ever gets stuck is if it tries to swallow something it shouldn't (socks are the main culprits).
PostPosted: February 18th, 2016, 11:31 pm
by justflie
XV-11 owner here. She's been going strong since October of the first year of availability so i guess around three years ago. I've replaced the battery twice, but that's all for non-routine maintenance. I thought she bit the dust after having a run-in with Playdough (brush stuck message) but I brought it back to life but shutting down and starting up. I was kind of hoping to have an excuse to buy a D85. That damn 20% BBB coupon is staring at me!
PostPosted: February 19th, 2016, 12:45 am
by JEfromCanada
The poll, which I'm sure was created to measure build quality, is a bit biased. Early adopters who opt for a purchase of a new model are more likely to be confronted with "new product" issues. I had good results with my initial purchase because I didn't jump on the Neato bandwagon until the XV-11 was a proven product with initial bugs shaken out. Similarly, I've had good luck so far with my Botvac, having not bought it until after the D series was released. I'd be curious to know where those robots that had initial quality problems were purchased. Could they have come from merchants who bought massive quantities of early stock and had them in the warehouse for a long period of time?
It would be useful to know how many times a particular model needed to be returned before a *GOOD* unit was received - and to have that poll broken down by model/generation (i.e. XV, Signature, Botvac, D-series, Connected).
PostPosted: February 19th, 2016, 5:18 am
by Wing Nut
JEfromCanada wrote:The poll, which I'm sure was created to measure build quality, is a bit biased. Early adopters who opt for a purchase of a new model are more likely to be confronted with "new product" issues.
Indeed, I can't recall when my first XV-11 had a suspension spring failure - was it 1, 2 or 3 years into ownership? So I'm not about to skew the vote by taking a guess. I have 2 XV-11s now - both are 5+ years old and still going strong. I've replaced at least one capacitor and added a tiny bit of packing to resolve a 'Bin' error.
I rescued my 2nd XV after it had multiple charging issues caused mainly by a failure to update the firmware to the 'wriggle' version - again, not something I'd enter in a reliability poll.
PostPosted: February 20th, 2016, 4:26 am
by robocleaner
The poll isn’t intended to be a detailed scientific study... just give a general, composite indication of longevity based on real user experiences.
With the benefit of hindsight, different/more options might have offered a fuller picture.
PostPosted: February 21st, 2016, 3:09 pm
by ivanilia2
I've had my NEATO connected for four months now and it's still going strong. It has to clean 3 floors 3 times a week. So almost every day it's up and running. Very happy with the cleaning result sofar. Sometimes it gets lost in "our difficult to map" house, but overall does a pretty good job.
PostPosted: July 24th, 2016, 10:39 pm
by marlowefamily
Mine always die roughly around 3 years, sometimes a few months before and othertimes a few months after.
PostPosted: July 26th, 2016, 1:50 am
by Frueds
Hiya all nice people here.
Our Neato Botvac Connected is/was a marble and a diamond. After just 2 weeks of letting it clean our moderate home of say 1200 square feet it started behaving odd and becoming lazy. We treated him nice. We cleaned him with our Miele C3 vacuum twice a week. What he does, He finishes a job big or small, and we want him to clean another job or again all he asks for is to be fed more charge. He refuses to work more even when he has 2 and 3 bars on the battery. After a few days of the first problem he came up with a new trick, after 5 minutes vacuuming with a clean diaper..I mean clean dust bin he asks to empty his dustbin while he keeps moving and cleaning he keeps displaying that the dust bin should be cleaned. We pause him, we see almost NO dirt yet in there, but he insists to be cleaned.
Another issue is that when he is latched on to the base while the base is feeding him he is blinking his 2 lights but not together, one goes On while the other goes Off, and vs vers., they arent blinking 2gether On and Off. Weird!
We called Neato several times while trying to do all kinds of reset to factory setting.. nothing worked. I asked "How about tell me to disconnect the main battery AND the small battery somewhere hidden in there?"..
They said: If you do that then warranty is void.
All what I have seen so far out of all robot vacuum cleaners is that this is suppose to be the most practical as straight forward robot vacuum cleaner, but now its behaving like a spoiled brat!...
Please excuse my silly sense of humor.
Cheers,
Frued
PostPosted: July 26th, 2016, 4:54 am
by JEfromCanada
Frueds wrote:We pause him, we see almost new dirt yet in there, but he insists to be cleaned.
My Neato (not a Connected, but rather a Botvac 80) used to bug me about emptying the bin. I think it does this after a certain number of jobs. Anyway, I found there was a setting in the menu that stops these annoying alerts. I've been much happier since disabling this warning.
PostPosted: July 27th, 2016, 11:17 am
by kalidiso
6 mths and not charging anymore.. is it the base or the robot?? How do i tell?
PostPosted: July 27th, 2016, 11:45 am
by vic7767
First, what model robot are you having this issue with ? Second, do you have a multi-meter that you can use to measure output voltage of the power supply, as well as stored battery voltage ? Third, download the free program NeatoControl , found within this forum that can be used to test various functions within your robot.
