My quest for a cheap LCD for Neato XV!
Re: My quest for a cheap LCD for Neato XV!
Postby AlainCAN » October 30th, 2018, 4:33 pm
:clap: :cheers: :thanks:
AlainCAN
Postby KoosF » November 6th, 2018, 6:04 am
Comment on Tlt PCB.
My Neato display went blank. I bought the lcd ERC128128-3 at Buydisplay and the pcb on OSH Park.
The repair did not work and never could have worked. See picture below.
The pcb connections are straight and should have been crossed, pin 1 lcd to pin 1 pcb, etc.
KoosF
Postby neato58 » November 12th, 2018, 7:47 pm
In my case (see above), the lcd ERC128128-3 at Buydisplay or ebay and the pcb on OSH Park did work.
See my previous posts with pictures.
I am sure I will do better job on the next one and i will get it to work on the first try.
neato58
Postby gollum » December 5th, 2018, 3:31 pm
I ordered ERC128128FS-3 from ebay and pcb from OSH Park.
I soldered the pcb from osh park, the connector that came with the display all together to the neato display pcb.
The problem is I didn't read the whole topic thru :D
At first I didn't flip the LCD (my connector has contacts on the top so it looked OK).
Of course the LCD was blank.
(the photo if before flipping)
Then I did flip the LCD, and to be able to connect the ribbon to it I folded it and put in the connector.
The problem is the LCD is still blank.
Could I have damaged it when it was connected inverted?
gollum
Postby Fred_75 » December 15th, 2018, 6:33 am
Hello!
I am glad that everything turned out, thanks to this topic, many robots have a chance ...
slybas wrote:C6 with 12v using my dime converter who is not up to scratch against 24volts
Can you clarify to which pins on "cruz" board the converter is connected?
Fred_75
Postby AlainCAN » December 15th, 2018, 5:54 pm
You have to connect the wire on the C6 capacitor, the pin closed to the ribbon cable, like on the picture from slybas. Was it you question ?
AlainCAN
Postby Fred_75 » December 15th, 2018, 11:56 pm
AlainCAN wrote:4 - Solder the red and black wire on the main board, the red wire goes to the first pin of U23, the black wire on the capacitor C143, side closed to the plastic like on this picture :
Interests, where on the cruz board it is necessary to connect the red and black wires, in this post we talked about the binky board... slybas did not mention it
Fred_75
Postby AlainCAN » December 16th, 2018, 8:20 pm
Ah ok sorry, you can pickup the power directly from the power connector coming from the battery (the bigest connector on the board, with the red and black wire on it. it is the power coming from the battery.
AlainCAN
Postby Fred_75 » December 16th, 2018, 9:35 pm
AlainCAN wrote:Ah ok sorry, you can pickup the power directly from the power connector coming from the battery (the bigest connector on the board, with the red and black wire on it. it is the power coming from the battery.
Thank you, I will try this. There were also such thoughts, but it was embarrassing that the converter would be on all the time ... Is this normal?
Fred_75
Postby AlainCAN » December 18th, 2018, 11:13 am
Yes It's normal, it will be powered up all the time, the screen will be turned off by the communication bus at the same time as the backlight will be switched off.
AlainCAN
Postby gd44 » January 19th, 2019, 1:28 pm
Hello
Just to say Thank you to AlainCan !
I have the same problem on a Neato Essential with a blanck screen !
Now it work fine !!! :clap:
By the way, I replace the C10 condensator with a strongest .
8-) :thanks:
gd44
Postby postitman » January 21st, 2019, 4:17 pm
Hello all,
First of all, thank you so much Tris for your thread.
After many search, I havn't found the pinout connection between the breakout PCB and the Neato PCB.
I've bought the screen 128x128 and 2 breakout PCB. I would like to check the inverted screen before anything.
Could you send me pinouts : from where (from the pin 1 to 24 of the Breakout PCB) to where (in the Neato PCB).
Sorry for my bad English.
Best regards
postitman
Postby AlainCAN » January 23rd, 2019, 3:42 pm
gd44 wrote:Hello
8-) :thanks:
Hi @gd44, thanks for your feedback and congratulation !
AlainCAN
Postby banasr » February 6th, 2019, 4:16 pm
Hello.
Another Neato xv signature repaired by method AlainCan.
and the end result
:thanks: to AlainCan
banasr
Postby AlainCAN » February 8th, 2019, 6:54 am
banasr wrote:Hello.
Great Job ! congratulation :thumbup:
AlainCAN
Postby linvinus » February 21st, 2019, 8:59 am
AlainCAN, thank you!
yet another neato blinky was repaired with L7812CV.
linvinus
Postby AlainCAN » February 22nd, 2019, 4:56 am
Well done linvinus ! Thanks for your feedback !
AlainCAN
Postby banasr » February 23rd, 2019, 5:48 pm
:text-bravo: the cheapest solution to the problem
banasr
Postby z_thompsonpa » March 7th, 2019, 12:25 am
I ordered a replacement lcd screen and breakaway board, but figured I would try @AlainCAN method while waiting on the parts from Asia.
I would like to report that it fixed my blank white lcd screen problems, initially. I started noticing issues while trying to charge the batteries back to full again. The Neato vx-12 would keep restarting and resetting. I began troubleshooting the problem and decided to remove the c5 capacitor lead from the buck converter. The auxillary voltage source on c5 was no longer needed for the lcd to operate properly. I left it attached to the board, though, just in case I decide to install a wifi card at a later date.
It appears the AlainCAN method "jump-started" my lcd screen. (or maybe a coincidence)
At least if the screen decides to go bad again, I have spare parts on the way, but I am still intrigued.
Has anyone else tried removing the buck converter after getting their screen working?
z_thompsonpa
Postby KoosF » March 12th, 2019, 11:57 am
Does anyone know the specification of component D6 on the lcd board ?
KoosF
PreviousNext
Users browsing this forum: ASTMedic, BrettS, im1kissfan, Metalworker, mobzd, ps0001, RockinRay, Sobo, someoneclever, vic7767, wassct and 188 guests
