Postby jpccusa » November 5th, 2016, 1:58 pm
This is the connector attached to the board.
And this is the LCD screen ribbon.
The ribbon was inserted into the connector with the golden pads touching the white part.
On a side note, is there a way of fixing/working around the /Res pad issue? The wire that WAS connected to it came loose and now there is virtually nothing left to solder it back to. :?
jpccusa
Postby mfortuna » November 5th, 2016, 3:07 pm
Your pictures are not showing up for me.
As far as the res pad is concerned, you can scrape off the coating on the etch that leads to the resistor and solder it there. You could also solder it to the side of the resistor labeled R10.
Postby JEfromCanada » November 6th, 2016, 2:25 am
mfortuna wrote:Your pictures are not showing up for me.
That's weird... the pictures were showing for me before, but no longer. Maybe the OP deleted the pictures from where they were hosted?
Postby jpccusa » November 6th, 2016, 2:29 pm
I haven't changed anything (moved or deleted them).
I just now edited and re-uploaded the links. Let me know if you are still not able to see them.
jpccusa
Postby JEfromCanada » November 6th, 2016, 3:56 pm
JEfromCanada wrote:That's weird... the pictures were showing for me before, but no longer. Maybe the OP deleted the pictures from where they were hosted?
They're back now!
Postby jpccusa » November 6th, 2016, 3:59 pm
Great, it worked.
So, is my connection right? The golden part of the LCD ribbon faces the white part of the SIF connector, right?
PS; Scraping above the /Res pad worked. I have a better place to solder that wire now.
jpccusa
Postby oxdbxo » November 17th, 2016, 2:45 am
Tris, I have a question
in case of using this,
change the number like this
and visual representation,
Right?
oxdbxo
Postby jpccusa » November 17th, 2016, 3:45 pm
Quick update... IT WORKS!!!
The problem was indeed the loose /RES wire.
Thank you so much for all the help, specially Tris. I saved lots of money, learned new skills, and challenged myself to make this work.
:thanks: :cheers:
jpccusa
Postby Tris » November 17th, 2016, 7:22 pm
oxdbxo wrote:Tris, I have a question
Right?
That connector looks like it is designed for downward facing contacts (towards the board).
If this is so then you will have to flip/mirror the connections, like my MkII.
jpccusa's board is for upward facing contacts.
Assuming you still align the ribbon to pin 1 on the ZIF connector then pin 31 moves to pin 1, pin 30 moves to 2, etc.
The unused V0 would end up being on pin 31.
Tris
Postby Tris » November 17th, 2016, 7:28 pm
jpccusa wrote:Quick update... IT WORKS!!!
:thanks: :cheers:
Well done, I'm glad you managed gain so much from doing this project! :thumbup:
Enjoy your Neato! :D
BTW, the image isn't showing...
Tris
Postby asedovski » December 25th, 2016, 5:57 pm
Thank you very much!!!
It helps me a lot!
Juts few remarks based on my experience repeating this:
1) If you decide to proceed with LCD like it described (to fix mirroring) then you may leave original back light LED. In my case it was stayed on pcb while i was removing broken LCD and I decide to solder them out later one, but finally find out that its good to leave them as well as original plastic thing that was under the original LCD.
2) If you decide to proceed WITHOUT switching neato off (I was not sure in my result and decide to keep my current schedule in memory, If it wiped - then its almost impossible to setup it again without LCD) then you need to know that after connecting - you need to press buttons (In my case it was: start working, pause, stop) to see images on LCD, other wise it will stay blank (looks like each time you start/stop it reinitialize LCD)
3) If it your first time soldering 0.5mm (like it was for me) order two connectors!!! And ensure that you understand soldering techniques :) It was good that I order two of them like it was reccomended here.
Once again - THANKS A LOT, It is awesome!!!
PS: I was mistaken and order smaller LCD... but they still compatible :)
asedovski
Postby Tris » December 25th, 2016, 9:04 pm
Excellent, another XV saved! :)
Yes, retaining the original backlight is a great idea. I removed the broken LCD as a complete unit because I had no idea at the time that I would end up having to pull the backlight off!
Performing this (or any) repair with the power still on is very risky, it is never advisable to work on a circuit whilst it is powered! It would only take something like a dropped screw on the circuitry to blow it.
BTW, The schedule and other settings can be configured over USB using the program "Neato Control", available at...
https://bitbucket.org/heXor/neatocontrol
Which replacement LCD did you actually order, out of interest?
Tris
Postby oxdbxo » December 28th, 2016, 10:00 am
thx Tris....
but the screen was flipped horizontally....
lol :lol:
What is wrong with this?
oxdbxo
Postby Tris » December 28th, 2016, 3:04 pm
Flipped screen covered early in this thread!!
viewtopic.php?f=20&t=19263#p137446
Tris
Postby oxdbxo » December 28th, 2016, 5:06 pm
Tris wrote:Flipped screen covered early in this thread!!
holy cow! I missed that. How stupid...
Thanks bro
oxdbxo
Postby alexkilfr » February 15th, 2017, 5:21 am
Right?
Hi, I had bought the same adaptator as oxdbxo and done the same soldering as in the visual representation above. And my display still not showing anything !
any piece of advice ?
alexkilfr
Postby Tris » February 15th, 2017, 3:15 pm
You'll have to post some close up photos of your work, not much I can say otherwise apart from go back to square one and check everything. Closely.
Tris
Postby alexkilfr » February 16th, 2017, 2:36 pm
I have made some pictures about my soldering ( the solders begin to look ugly, due to my many tries after all my fails)
You'll find my photos in the URL attached
https://goo.gl/photos/HYZHB8YmqNEETpE47
BTW, thanks for the answer :)
alexkilfr
Postby Tris » February 18th, 2017, 9:40 pm
Get a multimeter and check that there are no short circuits between any of your wires. It looks like there may be a short here, circled in red...
Be sure to remove all solder spikes and splatters.
Tris
Postby alexkilfr » February 24th, 2017, 7:53 am
I have checked every solder and everything is good so far (no short circuits). I start thinking my lcd is not working. I'm gonna order a new one soon to test it.
alexkilfr
Users browsing this forum: BrettS, jdong, lanchez, leonicholson, Per L, vic7767 and 465 guests
