Page 1 of 2
Botvac Connected vs Botvac D5 Connected?
PostPosted: November 22nd, 2016, 1:58 pm
by Stormwind
Does anyone know if the Botvac D5 Connected has features the more expensive Botvac Connected does not?
It seems like the Botvac Connected is slightly older but is rated for more sq ft per run (larger battery?) and has Eco/Turbo mode and Manual Drive, whereas the D5 Connected has Find Me and Cleaning Stats - according to https://www.neatorobotics.com/compare-robot-vacuums/
Is the D5 Connected better than the Connected at some things? It is very confusing to me that the most expensive model doesn't have all or better features than the less expensive model.
Thanks!
Re: Botvac Connected vs Botvac D5 Connected?
PostPosted: November 22nd, 2016, 4:54 pm
by bcarpenter
Neato has also come out & said there will be a firmware update for the Botvac Connected to bring it up to the same features as the D5 Connected. Whether they do this or not will be interesting, as they haven't done a firmware update for existing bots for many years now.
PostPosted: November 22nd, 2016, 5:31 pm
by vic7767
I suspect all WiFi connected Botvacs will be flashed via the NeatoRobotics cloud.
PostPosted: November 23rd, 2016, 12:59 am
by glnc222
New Performance Specifications
Neato Robotics U.S. website has added details of the claimed performance such as area coverage possible with the vacuums, ranging from 1800 sq ft to 5000sq ft. Oddly the latest D5 Botvac connected specifies 4500sqft compared to 5000 for the original Connected. The inscrutable product designers. I do not think these figures represent coverage on a single charge based on experience with such equipment, the run times and battery capacity specs.
https://neatorobotics.com/compare-robot-vacuums/
Samsung's U.S. website also has some technical details not found on foreign sites. They've all been upgrading their marketing web pages lately.
PostPosted: November 23rd, 2016, 1:29 am
by bcarpenter
No, they say that this is with a 3-outing clean cycle.
PostPosted: November 23rd, 2016, 6:53 am
by markswift
The remote robot protocol API has the new functions, so the connected range WILL get an update.
PostPosted: November 27th, 2016, 3:55 pm
by Stormwind
bcarpenter wrote:Neato has also come out & said there will be a firmware update for the Botvac Connected to bring it up to the same features as the D5 Connected. Whether they do this or not will be interesting, as they haven't done a firmware update for existing bots for many years now.
Great! Is there a link to where Neato said that about the firmware update?
PostPosted: December 4th, 2016, 10:25 pm
by glnc222
CNET review November 2016
CNET is promoting the Botvac Connected as less expensive than the Roomba 980, and is ignoring other brands. Perhaps they declined to supply free test units.
https://www.cnet.com/topics/vacuum-cleaners/best-vacuum-cleaners/
PostPosted: December 4th, 2016, 11:17 pm
by glnc222
Two Pass Cleaning
Some time ago a member posted wishes for the robot to criss-cross the room in two directions for more thorough cleaning of carpet, debating the difficulty of such software and what not. So interesting CNET's review comments:
the Botvac Connected is more thorough: it sweeps the center of the room in both rows and columns, and edges along the walls multiple times, too.
That gives the Neato ample opportunity to pick up any debris it might miss on a single pass, though cleaning runs take a little longer as a result.
While CNET finds Neato the best performer in its tests, they fail to mention all these robots with small wheels cannot navigate on slick carpets handled only by the larger wheels on Powerbots or Dysons' tracked robot. The perfect robot remains elusive and they need to be selected based on customer's particular environment and preferences. Convenient returns with trial testing in the house can be needed.
PostPosted: December 5th, 2016, 10:25 pm
by jdong
It's worth mentioning, incidentally, that the Roomba 9xx's 2-pass cleaning does criss-cross the room in a different direction on the second pass. I thought it was an interesting detail -- a fairly logical idea.
PostPosted: December 12th, 2016, 5:19 pm
by someoneclever
Is it true that the D5 has a more powerful motor than the original Connected?
PostPosted: December 19th, 2016, 4:32 pm
by ngeorgieff
Neato released a new firmware update v2.2.0 with:
Version 2.2.0 includes:
Cleaning Summary with Coverage Maps & Cleaning History
Improved Wi-Fi Connectivity
Other minor fixes and enhancements
PostPosted: January 23rd, 2017, 10:39 am
by Face
the new firmware is also for D5?
it has added the map of rooms cleaned?
PostPosted: January 23rd, 2017, 4:56 pm
by someoneclever
2.2.0 is for the Botvac Connected only
PostPosted: January 24th, 2017, 3:37 pm
by Face
Any chance / rumors to have that feature also for D5 in a new firmware update ?
PostPosted: January 24th, 2017, 4:00 pm
by Face
Coming back to original question: the lack of Turbo mode in D5 should position that new robot to second place after the (old) Connected model ?
I've read for example that using Turbo mode on Botvac Connected move correctly all the hairs inside the trash bin while with Eco mode all the hairs remains all over the brush; don't want that D5 with only normal mode could cause that issue.
From another point of view normally a new model (like the D5) should be have inside better technology and construction over the old Botvac Connected, isn't it ?
I'm really undecided between these 2 ... :?:
PostPosted: February 1st, 2017, 1:49 am
by lifereinspired
Interesting info. I spoke at length with the Neato support team back in the fall after they had initial information about the D5 but before they had been fully trained in support for it. I was told in no uncertain terms that the Connected would NOT be getting some of the additional features that the D5 will have such as "Find Me" and Cleaning Stats because it's based on a completely different wifi chipset that allows the robot to connect to multiple wifi spots (and that is crucial for the additional features). I was told it would be impossible for this to be replicated on the Connected model. They also thought that the D5 would likely have a similar mode (or would have the same power as the Turbo) but would simply use the power mode intelligently (more power on carpets and less on hard surfaces for example). They wanted to confirm the information but that's what I was told. I have yet to confirm it myself. They said the main reason the Connected costs more is the LCD screen which some users require (who don't have a smartphone/device for instance). But they said there were definitely hardware upgrades in the D5 and recommended that unless I had to have an LCD, that I wait and go for the D5.
I wish I had more concrete info but wanted to share what I was told. Thanks for this thread!
PostPosted: June 8th, 2018, 4:35 pm
by Darmach
After over a year since last post (sorry for digging this up!) do you guys have any new insight on those two robots?
I'm torn between Connected vs D5.
Are there any significant firmware changes?
I have a long haired dog - so suction power might be critical, will non-D5 Connected be better?
On the other side I suspect D5 as a younger model, might be simply technologically better...
PostPosted: June 8th, 2018, 7:03 pm
by susantx3
The Botvac Connected is the previous generation model. It feels sturdier and heavier and can be programmed without using a SmartPhone. You also get 2 brushes. The included Spiral Blade Brush rarely needs to be cleaned of hair. It does not have FloorPlannerâ„¢ with virtual 'No Go' Lines. The Botvac Connected is near end of life but it is still shown on Neatos Page as being currently supported. There is Zero chance Neato will add any new features to the Botvac Connected. Neato does not make or service their product, it is all currently outsourced. When the current inventory of Botvacs connected is gone that will be it, Neato has moved on to a lighter body for all models (Old 9 pounds, new around 7.5 pounds) When Neato stops selling a model, they stop firmware updates. The Botvac Connected can be purchased on clearance for around 349-399.
PostPosted: June 12th, 2018, 11:01 am
by lifereinspired
We ended up trying the Botvac Connected and finally ended up returning it. It had some trouble navigating around certain things and frequently got stuck and couldn't right itself without intervention from me. Not ideal for an item intended to be able to run on it's own while a person is out. It also couldn't seem to just vacuum an area that we would set it in. For instance, a spill in the kitchen...it would instead of vacuuming that area just go around the perimeter and them head off and vac another room entirely and no amount of coaxing could get it to stay. We're planning on trying the new D7 which has the ability to block off problem areas in the app instead of relying on the magnetic tape - which should help a great deal on several things. No magnetic tape around the house and easy ability to have the vac easily avoid areas it might find it gets easily stuck. Also, nice to easily be able to avoid things like dog water bowls. :) I know that doesn't help about the Connected to DO comparison directly but definitely but from a place where you can return if you have issues.
