Neato Connected Software Update v2.2.0
Postby ngeorgieff » December 19th, 2016, 4:36 pm
Neato released a software update including Cleaning Summary with Coverage Maps, Cleaning History and improved wifi connectivity.
https://www.neatorobotics.com/my-neato/ ... ed-robots/
What's New?
Version 2.2.0 includes:
Cleaning Summary with Coverage Maps & Cleaning History
Improved Wi-Fi Connectivity
Other minor fixes and enhancements
ngeorgieff
Re: Neato Connected Software Update v2.2.0
Postby vic7767 » December 19th, 2016, 5:28 pm
This update only requires a 1 Gb USB flash drive format Fat32 and copy an unzipped copy of the NeatoRobotics supplied Zipped file that is downloaded from their site. A short OTG micro USB to Female USB 2.0 cable is used to flash the Botvac connected.
Postby joker18 » December 20th, 2016, 2:30 am
Thank you! I updated mine now.
joker18
Postby plex » December 20th, 2016, 4:36 am
vic7767 wrote:This update only requires a 32 Gb USB flash drive format Fat32 and copy an unzipped copy of the NeatoRobotics supplied Zipped file that is downloaded from their site. A short OTG micro USB to Female USB 2.0 cable is used to flash the Botvac connected.
A 1GB fat32 flash drive is enough - this is what Neato says...
plex
Postby vic7767 » December 20th, 2016, 10:18 am
plex wrote:A 1GB fat32 flash drive is enough - this is what Neato says...
Thank you for the correction.
Postby someoneclever » December 20th, 2016, 8:32 pm
Has anyone seen any navigation changes in 2.2? Also where is Find Me?
someoneclever
Postby Lhartman89 » December 20th, 2016, 9:17 pm
Has anyone else had their neato only update to 2.1.1 and not 2.2.0. I tried updating my botvac connected tonight and it is showing version 2.1.1 like it never finished upgrading to 2.2.0.
Lhartman89
Postby someoneclever » December 20th, 2016, 9:19 pm
Lhartman89, look in the RobotData folder. Do you see a .bin folder with 2.2.0 in the name? Check subfolders as well
someoneclever
Postby someoneclever » December 20th, 2016, 9:33 pm
Lhartman89, try running the update again
someoneclever
Postby Lhartman89 » December 20th, 2016, 9:34 pm
I figured it out. I had to move the Neato_2.2.0_296.bin file from the AutoUpdate folder into the main RobotData folder and delete the Neato_2.1.1_247.bin file. Then I ran the update again and now it is on version 2.2.0. Thank you for the help! For some reason it didn't automatically update like it was supposed to.
Lhartman89
Postby someoneclever » December 20th, 2016, 9:35 pm
The robot must have not seen the 2.2.0 file
someoneclever
Postby someoneclever » December 20th, 2016, 9:36 pm
Good to see you've updated too!
I updated earlier today and I had to run the update twice-the first time it stayed on 2.0.0 with no errors
someoneclever
Postby Lhartman89 » December 20th, 2016, 9:40 pm
I ran the update about 4-5 times, tried re downloading the file and doing it again. I was trying to even find a way to do a hard reset, but it looks like that is not possible. Then I decided to try what I did above and it took. Like you said someoneclever, I guess it must have not seen the other folder/file.
I am looking forward to seeing how the mapping works/looks.
Lhartman89
Postby someoneclever » December 20th, 2016, 9:43 pm
Here's what the mapping looks like
Teal areas were covered, white bits are walls and obstacles (not including mag strips) and the darkest bits were where Neato could see but not clean
someoneclever
Postby joker18 » December 21st, 2016, 2:18 am
Question, how did you make it show area in m2?
Mine is showing ft2
joker18
Postby someoneclever » December 21st, 2016, 9:26 am
I set my region to United Kingdom
someoneclever
Postby plex » December 21st, 2016, 10:43 am
Have you noticed any difference, beside the cool map feature in release 2.2? Image
plex
Postby someoneclever » December 22nd, 2016, 7:18 am
Nope
someoneclever
Postby orangeblue » December 29th, 2016, 9:15 pm
Hello,
I am trying to upgrade from 2.0 to 2.2. I have followed the instructions exactly as the tutorial shows, and tried a couple of suggestions from this thread. When I press software update, the pinwhell spins for about 1-2 seconds the light on my jump drive flashes once then it stops.
I have tried 4 different jump drives, reformatted them all. I have tried leaving the .bin files in the root folder and just putting the .bin file by itself on the root file of the drive. The drive is clean and has the default name.
I appreciate any suggestions or help! :cheers:
-Chris
orangeblue
Postby someoneclever » December 30th, 2016, 7:49 am
orangeblue, try redownloading the update files from Neato's website. Does your robot give an error message when attempting to update?
someoneclever
Next
Users browsing this forum: BCCISProf, Erithtotl, fuzzydunlop, im1kissfan, johnnyh, someoneclever, teokakav and 396 guests
