My kitchen shortcuts my Connected
Re: My kitchen shortcuts my Connected
Postby glnc222 » June 27th, 2017, 10:33 pm
Shorting the charging contacts can also occur against metal furniture legs, brushed aluminum, chrome etc.
A German user used foam pads on the rear to prevent contact with walls or furniture while still allowing charger contact. German roboter-forum pics
http://www.roboter-forum.com/showthread.php?22176-MOD-Ladekontaktekurzschluss
Postby Pumbi » November 30th, 2017, 8:27 am
The picture from the german site
Pumbi
Postby pdjms1 » Today, 3:57 pm
Hope I'm not beating a dead horse but I believe I have recently come to a similar issue but one that has caused in the failure of a diode or some other component. My botvac Connected now stops about 18 inches from the base at a slight angle and claims its charging when it is not. What I am thinking is there is a diode that should sense a load when the bot is close enough to the charging station so the vac knows when to stop moving (i.e. successful dock procedure). When I called a fix your robot service they said it was likely related to this issue (static discharge back feeding into the system causing a short in the Mother board) and it would likely be about $100 + shipping both ways. While this isn't terrible when comparing to the purchase of a new unit... I would like to try my luck out at fixing it myself and dusting off my old blinky board skills. Is there a thread that has information on how to fix the "phantom charging" (as I have heard it called) in a botvac connected?
Thanks in advance, seeing the responses on other posts while trying to find the answers to my issue has revealed a very informed and helpful community here.
pdjms1
Users browsing this forum: aarolar, leonicholson and 368 guests
