Disabling wheel sensor
Postby tocs » January 30th, 2017, 7:14 am
Hi Everyone,
I've got a Botvac Connected and I'm getting the "please put me down on the floor" message.
I've connected to it using Neato Control and It is indicating that the "snsr_left_wheel_extended" always has a value of true. The right wheel is fine and switches on and off as I pick it up. It's just the left wheel that is not working. I can also hear an audible click on the right wheel when I pick it up, but not the left.
Is there a quick way to just disable the sensor through the software.
I've discovered the "diagtest disablepicukupdetect" command but it doesn't do me much good.
Further, if anyone has any experience on how to replace the sensor that is broken that would be great as a longer term fix.
Any advise would be great appreciated.
Cheers,
Tocs.
tocs
Re: Disabling wheel sensor
Postby glnc222 » January 30th, 2017, 7:21 pm
I think that sensor is a simple lever action microswitch. At least that was used on the XV models. It would connect a power supply voltage like 5v or a ground to a digital cpu input. Compare voltages on the pins pressed and released. It can be measured with a multimeter. Unlike the XV, access to the wheels requires full disassembly, buried in the bottom, but construction is modular. See Mods & Repairs list main page for links to videos and instructions. A long shank T10 torx screw driver is needed.
It was easy on XV's to tear off the little lever, but this did not affect operations except maybe not detecting lifting off the floor so much (the cliff sensors are also used). It depends on software. The switch should be easily replaced but check for shorts in wiring and what not first. Worst case the cpu input is not working.
It may be possible to simply jumper or short out the switch in the normal operating position, or to tape the lever pressed if that is the needed configuration.
Postby shirgal » January 31st, 2017, 6:45 pm
tocs : if you open the cover just follow the 2 twisted wire gray+brown from each wheel switch to the board,
you can disable the left one by making short on the wire going to the board.
shirgal
Postby chrizz29 » September 23rd, 2018, 6:00 am
I know this is an "old" thread, but it helped me none the less. I didn't get the exact answer I needed, but sometimes you just need a nudge in the right direction.
My Botvac D5 Connected developed the same issue a few days ago. The left wheel microswitch dead - no clicking sound. For some reason at exactly the same time as Neato presented the new model - go figure... :o)
I used the "Neato Control" application as suggested by "tocs" to diagnose the issue further: viewtopic.php?t=18173
I tried running extra wires from the right wheel connector to the left wheel connector, but then i found out, that they use different voltages - 1,7 V on the right wheel and (i think) 3,3 V on the left wheel). So this didn't help much - other than the right wheel sensor also showing "true" at all time.
Also tried the solution from "shirgal" - shorting the wire to the board - but this didn't seem to to the trick either (or I didn't do it properly?).
In the end the solution was (as they sometimes are) really simple: Just pull out the left wheel sensor plug from the main board and let it hang loose.
Now the sensor always returns "false" and the Botvac D5 can continue keeping our house clean(er)... :o)
I don't think the missing wheel sensor will cause too much trouble. The Botvac will still stop if we pick it up, as the right wheel sensor still works.
I hope this can help someone else out there!
Regards,
Christian
chrizz29
Users browsing this forum: BrettS, im1kissfan, Ionic, jdong, johnnyh, leonicholson, Miles267, minh1010 and 373 guests
