how to test the side brush motor on Botvac models
Postby bruce9241 » February 17th, 2017, 9:45 am
Hello,
Does anyone know how to test this side brush motor? On the Neato Control software it has the side brush testing option, but it doesn't seem to work. How do I know if a side brush motor works besides actually installing it and running the vacuum?
bruce9241
Re: how to test the side brush motor on Botvac models
Postby Tris » February 18th, 2017, 1:01 pm
I think it's a bug in Neato Control. My workaround on V3.3:
1. Tick "Brush" - the main brush will start, speed is irrelevant.
2. Tick "Side Brush" - the main brush will stop and the side brush will start.
3. Untick "Brush" - should be no change in motor operation.
4. Untick Side "Brush" - side brush stops.
Tris
Postby glnc222 » February 18th, 2017, 2:01 pm
Text commands (from the Help command) were posted for the side brush at viewtopic.php?p=132219#p132219
SetMotor SideBrushEnable etc.
SideBrushEnable - Enable Side Brush Motor motor
SideBrushDisable - Enable Side Brush Motor motor
SideBrushOn - Enable the Side Brush
SideBrushOff - Disable the Side Brush
SideBrushPower - Side Brush maximum power in milliwatts (presumably has a default value if omitted)
Neato Control just sends such commands with its graphical interface. These commands are not included in the USB manual at the Neato website, never updated for Botvac.
[edit] SetMotor requires TestMode ON -- how Neato Control turns that on and off don't know, maybe automatic. Test mode turns on power lines to motors, which then turn under PWM signal controls. TestMode must be manually turned off (done by orderly exit from Neato Control I think, disconnecting before closing).
Users browsing this forum: mfortuna, TechGuy, vic7767 and 319 guests
