Page 4 of 4
Re: Neato ESP8266 Remote control (www.neatoscheduler.com)
PostPosted: August 4th, 2017, 3:34 pm
by Schwammal
I installed the code on the nodemcu today and do have the same issue with the missing web server. The ESP opens a hotspot and is pingable but is not accessible by the GUI. I recognized that the code in github was not the latest one (1.5 vs 1.6) Any chance to get the latest 1.6 code to see if that solves the issue?
Cheers
Flo
PostPosted: August 14th, 2017, 5:55 am
by kobold
Schwammal wrote:I installed the code on the nodemcu today and do have the same issue with the missing web server. The ESP opens a hotspot and is pingable but is not accessible by the GUI. I recognized that the code in github was not the latest one (1.5 vs 1.6) Any chance to get the latest 1.6 code to see if that solves the issue?
Cheers
Flo
I had the same issue. To resolve it I commented out mDNS and connect to the device by IP.
PostPosted: August 17th, 2017, 3:04 pm
by Schwammal
I have tried that before with and without mDNS running in the code but was not successful. I have no idea why that is not working
Cheers
Flo
PostPosted: October 5th, 2017, 7:02 pm
by t_kinesis
I got a sample unit (thank you!!) and finally got it into my Neato recently. Things went pretty well at first even though the battery seemed to drain much faster than before. Just recently the clock changed from Central time to another time zone. I tried setting the clock on the Neato and changing my time zone setting on my profile at neatoscheduler.com. Any ideas about how else to fix this? Thanks!
PostPosted: October 9th, 2017, 7:29 am
by hoopsta1423
I'm getting an error when I try to delete a device from my profile on the neatoscheduler.com website
"Fatal error: Call to a member function bind_param() on a non-object in /var/www/neato/pages/myProfile.php on line 18"
Anybody else have that issue?
PostPosted: October 11th, 2017, 10:45 am
by swoby
Hello
I need your help:-)
When I upload the compiled program to ESP8266 via Arduino
After uploading, I see the Neato WiFi network.
I can join, the IP address of the server is 192.168.4.1, The administration page does not load. Ad via IP or "Neato.local".
After power off and I can not see the WiFi network anymore.
If I upload again through the Arduino program, I see again only once wifi network.
I tried to upload frimware over Python now...
esptool.py --port SERIAL-PORT-OF-ESP8266 write_flash -fm dio 0x00000 FIRMWARE-NAME.bin
The program is successfully uploaded, but I do not even see the WiFi network...:-(
What am I doing wrong?
I have ESP8266 12F
It must be first connected to the vacuum to see the network...?
Thank you for your help and the beautiful project
Swoby
PostPosted: October 13th, 2017, 3:23 pm
by stiles
Has anyone tried this on an XV-11? I have a few ESP12 laying in a drawer that I've been wanting to use :)
I'll see if I can find some time this weekend to wire one to my XV11 so that I can test the firmware. I assume once a sketch with OTA enabled has been pushed, we can push additional updates through the Arduino IDE? That would simplify firmware updates on my end if I need to troubleshoot XV-11 integration. I could also provide HawtDogFlvrWtr with a remote connection if you would be interested in adding support for the XV series?
PostPosted: November 28th, 2017, 4:58 pm
by danikd
Hello, any chance to be working on later XV signature models with only USB? I have spare unit for test so ... Thx for info. Daniel
PostPosted: December 4th, 2017, 12:11 pm
by wjflier
what happened to neatoscheduler.com?
PostPosted: December 4th, 2017, 1:58 pm
by scuellar
Yesterday server www.neatoscheduler.com started with wrong timing having all robots working at midnight :shock:
Today is gone!
Any update and what happened?
PostPosted: December 4th, 2017, 4:17 pm
by wjflier
I'd love to have a cleaning complete command, so that neato returns home, instead of a stop command that leave neato out in the room where the command was implemented.
PostPosted: January 16th, 2018, 10:26 pm
by Fillimerica
Is this project still alive?
The website is working and I have established an account, but I am not sure of the exact components to purchase.
I found these:
USB interface: https://www.ebay.com/itm/FT232RL-FTDI-USB-3-3V-5-5V-to-TTL-Serial-Adapter-Module-for-Arduino-Mini-Port/222721031019?epid=1983299799&hash=item33db353b6b:g:vdoAAOSwEZdaDLpc
and
ESP-12 board (F is cheaper than S): https://www.ebay.com/itm/ESP8266-ESP-12F-WIFI-Microcontroller-802-11N-Module-Arduino-NodeMCU-MicroPython/152766041599?hash=item239190cdff:g:kd4AAOSwPypaUHRO
Left a message at the website but the developer may be away. Is it worth going forward and trying to build the device?
Thanks.
PostPosted: February 2nd, 2018, 9:38 pm
by waspie
Fillimerica wrote:Is this project still alive?
I found these:
and
Thanks.
Mine hasn't worked right for a while. pretty sure this guy is MIA
PostPosted: April 23rd, 2018, 1:28 pm
by HawtDogFlvrWtr
I'm here. For some reason I got no notifications of posts in the forum though it's enabled. What's the problem?
PostPosted: April 23rd, 2018, 1:32 pm
by HawtDogFlvrWtr
For those having issues with the device not connected to their neato, it needs to be connected before it will work as intended, because it needs to get the device serial information to move forward with registering on the site. @waspie, what is your device doing or not doing?
My apologies for not rolling by here sooner. I was working on an independent web service for folks who want to host their own instead of using neatoscheduler.com. I have also been working on additional features and fixes to the previous firmware.
PostPosted: April 23rd, 2018, 1:38 pm
by HawtDogFlvrWtr
If you're having a problem, shoot me an email at hawtdogflvrwtr@gmail.com and i'll help you out.
PostPosted: April 23rd, 2018, 4:41 pm
by wjflier
Having issues with the Map display, Tried on two pc's but no joy.
PostPosted: April 23rd, 2018, 5:57 pm
by HawtDogFlvrWtr
Fixed. Thanks for letting me know.
PostPosted: May 28th, 2018, 8:49 am
by joyride76
Hi folks,
I've just bought a new D85 from amazon and I'm looking to mod the robot as soon I can
With a friend of mine I'll be alble to load the code in to the ESP module but before to go ahead I need few questions:
1. is it possible to install the module without voiding the warranty? I'm worried to slder cable on the console pin, any suggestion to grant the connectivity between the module and the console port?
2. can I use a MINI nodemcu? that's only to facilitate the programming phase of the ESP ex:(https://www.ebay.it/itm/Mini-NodeMcu-Lu ... SwfaBawmSM)
3. I've created a new account on https://www.neatoscheduler.com/home.php but I didn't received back any email, how to proceed?
4. the website will be never discontinued?
That's all... for now
Stefano
PostPosted: May 28th, 2018, 3:36 pm
by joyride76
Just last question...
I've a ddns to point to my house services it would be possible send a command to my robot directly using ddns address and port forwarding on the router?
