Botvac D75 battery connector on the motherboard
Postby TechGuy » May 25th, 2018, 10:29 pm
I am working on a Botvac with battery connector pins became loose at the motherboard. These two pins are still at their respective holes on the motherboard. I can rotate them around. I soldered these pins to the motherboard. But this Botvac is still not power up.
I am just guessing. These pin may be connected to the middle layer copper foils. When these pins became loose and turning in the hole, the connections to the middle layer copper foils were broken.
Anyone has info. about the battery connector pins connected to which components. Circuit diagram showing the battery connector will be great. TIA
Re: Botvac D75 battery connector on the motherboard
Postby shirgal » May 29th, 2018, 6:38 pm
The pins are soldered to upper layer of the board, not to the middle.
I have replaced them (all pins for the battery board)in complete with no problem.
shirgal
Users browsing this forum: BrettS, jdong, txenakis, vic7767 and 405 guests
