What do you need to do when doing multi-floors?
PostPosted: November 25th, 2018, 4:15 pm
by shatain00
So assuming (still comparing) I have my NEATO D7 on the main floor (great) and lets assume it works fine ...
Now I want to bring it up-stairs (2nd floor) - what do I need to do so that I am sure it cleans the entire flood?
I assume I need to carry up the unit as well as the charger, and place the charger always in the same place on all floors so that it knows where to go back if it needed to recharge and resume half-way through?
Thanks,
Re: What do you need to do when doing multi-floors?
PostPosted: November 25th, 2018, 5:44 pm
by JEfromCanada
You should be able to place the charger anywhere (not necessarily the same place). The Neato "discovers" the location of the charger as it's cleaning (the charger is equipped with a reflective "pattern" that the Neato can recognize with its scanner), and Neato will remember the location of the charger.
PostPosted: November 26th, 2018, 12:32 pm
by Noge
in the app go to the floorplan you created.
on top of screen click on the name you gave to said floorplan.
now it will ask you if you want to ADD a floorplan.
follow instructions
