Neato botvac cheap motors replacement
Postby egisklaip » January 23rd, 2019, 2:22 pm
egisklaip
Re: Neato botvac cheap motors replacement
Postby Brett » January 29th, 2019, 7:24 am
Your problem is not the motor but the getting the right pulley on there...
Postby egisklaip » January 31st, 2019, 3:58 am
What do you meen pulley? Sorry I am not good at english.. My Side brush motor is dead (tested with soft) so looking for cheep replacment. What is orher tour options???
egisklaip
Postby Brett » February 1st, 2019, 2:22 am
You will find a motor easily, cheap too. But it will look something like this when you buy it:
But your Botvac motor has a brass pulley on it to drive the rubber belt, like this:
Not my pics!
I have not found a reliable way to remove or fit the pulley without damaging the motor.
I would be keen to hear if others have managed it?
Postby mfortuna » February 1st, 2019, 7:54 am
This type of gear puller may work. I have a very simple version of it and it worked fine the few times I used it.
https://www.towerhobbies.com/cgi-bin/wt ... gIfX_D_BwE
Postby egisklaip » February 1st, 2019, 3:13 pm
I even did not have it mind. Any other cheep options how to remove and fit the pulley? For 1 time to buy such device it is not good idea. Anyone has bought a gear puller from aliexpress? something like that https://www.aliexpress.com/item/Univers ... st=ae803_3
egisklaip
Postby mfortuna » February 1st, 2019, 8:24 pm
That should work as long as there is enough space between the gear and motor.
Postby egisklaip » February 3rd, 2019, 7:25 am
I removed a pulley without any problem with screw driver.
Next question - I have side brush motor which is not working. Writen specification on it rf-500tb-11660 YD104421. I can easely find motor replacement rf-500tb-11660 BUT THE RPM is different. What is right RPM of NEATO botvac side brush motor?
egisklaip
Users browsing this forum: ASTMedic, BrettS, im1kissfan, jdong, jomo, lanchez, someoneclever, vic7767, Wing Nut and 216 guests
