Neato d3 red flashing lights
Postby Mattb83 » February 8th, 2019, 10:52 am
Hi everyone.... new to the robot vac world and have a Neato D3 with 2 blinking red lights???
Mattb83
Re: Neato d3 red flashing lights
Postby TechGuy » February 8th, 2019, 3:53 pm
How old is your battery?
Is there any error code?
Postby Mattb83 » February 8th, 2019, 4:59 pm
Thanks for your reply. 18mths maybe? Error codes? I can only see the lights flashing? How can I get the error codes
Mattb83
Postby fmulders » February 9th, 2019, 5:06 am
Error codes should be in the app.
You can start by performing a reset: Hold button for 8 sec till it shuts off.
Than switch on again by pushing the button again...
fmulders
Postby Mattb83 » February 9th, 2019, 6:41 am
Mmmm, only thing is I’ve bought this as faulty (should’ve mentioned that earlier) so I haven’t even had the chance to connect It to the app yet? I was looking on another thread and they mentioned about a bit of software so that you can plug the D3 into your laptop..... maybe this would give me the fault code?
Mattb83
Postby fmulders » February 9th, 2019, 11:15 am
https://bitbucket.org/heXor/neatocontrol/downloads/neatocontrol.zip
Did you try the reset?
Does it start up after that,... start tune sound?
Does it leave the docking after pushing the button?
etc.
you should give us more information then only the red led's!
fmulders
Postby Mattb83 » February 11th, 2019, 3:17 pm
ok, ive had a chance to have a proper look at the D3, if i perform a reset the machine shuts down then i push the power button and it fires up with the blue "i" light and green "battery light alternate flashing for about 10 secs. then the green light stays on for about 10 secs then it makes a 5 tone tune (1 being the lowest tone) 1-2-3-4-3.
the machine dosent do anything other than that.... im about to take it apart to see if the battery is giving out any voltage...
Also the red lights are both solid on after all this has happened! No flashing.... just on.
I’ve taken the battery out and I’m getting about 15v across red and black..
ive also noticed that if i slightly pull it forward off of the charger it backs itself back?? so something is working??
Mattb83
Postby fmulders » February 11th, 2019, 5:53 pm
You can try to connect it to the app.
Install it on your phone. Push bumper to the left and hold it there together with the start button.
It should go off.
Start it up again en you should end up with a bot flashing the blue "i".
Now go back to the app and try to connect via Bluetooth. Then follow the instructions in the app to connect the bot to WiFi.
Finally if the bot is connected to the app, you might get an error message sending you in the right direction.
Good luck.
fmulders
Postby Mattb83 » February 12th, 2019, 3:43 am
Thanks for the reply, I tried the hard reset and it does the same thing and the blue “i” and green “battery” just flash alternatively. I have tried connecting via the app while it’s doing this but I’m not sure it’s actually in pairing mode..... I’ve also tried plugging into my computer via a usb cable but it’s saying there’s no driver on my laptop? I’ve downloded the program from a few different sources and still the same outcome? I take it everyone else’s program works ok?
Mattb83
Postby Mattb83 » February 12th, 2019, 5:14 pm
ok, ive finall managed to get into the neato control software and ive managed to get these figures?? do they help anyone??
____ Discrete: ____=
SNSR_DC_JACK_IS_IN=False
SNSR_DUSTBIN_IS_IN=False
SNSR_LEFT_WHEEL_EXTENDED=True
SNSR_RIGHT_WHEEL_EXTENDED=True
LSIDEBIT=False
LFRONTBIT=False
LLDSBIT=False
RSIDEBIT=False
RFRONTBIT=False
RLDSBIT=False
____ Analog: ____=
BatteryVoltage=mV=16148
BatteryCurrent=mA=-189
BatteryTemperature=mC=18600
ExternalVoltage=mV=0
AccelerometerX=mG=125
AccelerometerY=mG=86
AccelerometerZ=mG=945
CompassmeterX=mG=0
CompassmeterY=mG=0
CompassmeterZ=mG=0
GyroscopeX=dps=0
GyroscopeY=dps=0
GyroscopeZ=dps=0
IMUAccelerometerX=mG=0
IMUAccelerometerY=mG=0
IMUAccelerometerZ=mG=0
VacuumCurrent=mA=0
SideBrushCurrent=mA=0
MagSensorLeft=VAL=0
MagSensorRight=VAL=0
WallSensor=mm=255
DropSensorLeft=mm=71
DropSensorRight=mm=27
____ Buttons: ____=
BTN_SOFT_KEY=False
BTN_SCROLL_UP=False
BTN_START=False
BTN_BACK=False
BTN_SCROLL_DOWN=False
BTN_SPOT=False
IR_BTN_HOME=False
IR_BTN_SPOT=False
IR_BTN_ECO=False
IR_BTN_UP=False
IR_BTN_DOWN=False
IR_BTN_RIGHT=False
IR_BTN_LEFT=False
IR_BTN_START=False
IR_BTN_LEFT_ARC=False
IR_BTN_RIGHT_ARC=False
____ Charger: ____=
FuelPercent=87
BatteryOverTemp=0
ChargingActive=0
ChargingEnabled=0
ConfidentOnFuel=0
OnReservedFuel=0
EmptyFuel=0
BatteryFailure=0
ExtPwrPresent=0
ThermistorPresent=1
BattTempCAvg=18
VBattV=16.14
VExtV=0.00
Charger_mAH=0
Discharge_mAH=189
Mattb83
Postby Mattb83 » February 12th, 2019, 5:28 pm
also saw this info too:-
BaseID,0.0,0.0,0,0,
Beehive URL, beehive.neatocloud.com,
BlowerType,1,BLOWER_ORIG,
Bootloader Version,18283,,
BrushSpeed,1200,,
BrushSpeedEco,800,,
ChassisRev,1,,
LCD Panel,0,0,0,
LDS CPU,F2802x/c001,,
LDS Serial,OPS52616AA-0340473,,
LDSMotorType,2,LDS_MOTOR_MABUCHI,
Locale,1,LOCALE_USA,
MainBoard Serial Number,OPS52416,985dad2fc05e,
MainBoard Version,4,,
Model,BotVacD3Connected,905-0321,
NTP URL, pool.ntp.org,
Nucleo URL, nucleo.neatocloud.com,
QAState,QA_STATE_INVALID
Serial Number,OPS52716,985dad2fc05e,P
SideBrushPower,1500,,
SmartBatt Authorization,1
SmartBatt Data Version,512
SmartBatt Device Chemistry,LION1
SmartBatt Device Name,F164A10288
SmartBatt Manufacturer Name,Panasonic
SmartBatt Mfg Year/Month/Day,2099,2,10
SmartBatt Serial Number,23323
SmartBatt Software Version,2048
Software,4,0,0,1632,0
Time Local,Sun Jan 2 00:43:23 2000
Time UTC,Sun Jan 2 00:43:23 2000
UI Board Hardware,0,0,
UI Board Software,0,0,
UI Name,NONE
UI Version,NONE
VacuumPwr,65,,
VacuumPwrEco,65,,
Mattb83
Postby HiTec » February 12th, 2019, 9:16 pm
Thats your problem. Unfortunately no one seems to know how to fix it yet.
HiTec
Postby fmulders » February 13th, 2019, 2:32 am
You can try to reinstall the previous firmware and pray the QA state was still correct there.
This should do the trick:
1. Remove dustbin
2. Power of the robot by holding the Powerbutton until all lights are off
3. Push the bumper so the front left and and left switch are pressed and hold them
4. Power on the robot with the bumper buttons pressed and wait 10 seconds.
5. Release the buttons and wait for the robot to finish the downgrade, this will take some minutes.
6. Robot will reboot automatically with old firmware.
fmulders
Postby Mattb83 » February 13th, 2019, 3:36 am
Ok thank you so much for your help guys! I’ll try the downgrade option tonight and keep my fingers crossed!! If it doesn’t work is there a way I can downgrade it via usb?
Mattb83
Postby Mattb83 » February 13th, 2019, 2:24 pm
ok so ive done the downgrade but still no joy.... i think it has gone back to an old firmware tho?
it was 4,0,0,1632,0
now its 3,0,0,645,0
am i looking at the right bit?
GetVersion
APPassword,A35DC344
BaseID,0.0,0.0,0,0,
BatteryType,4,LIION_4CELL_SMART,
BrushSpeed,1200,,
BrushSpeedEco,800,,
ChassisRev,1,,
Cloud Selector, 2
LCD Panel,0,0,0,
SmartBatt Mfg Year/Month/Day,2017,7,14
Software,3,0,0,645,0
Time Local,Wed Feb 13 18:17:37 2019
Time UTC,Wed Feb 13 18:17:37 2019
UI Name,NONE
UI Version,NONE
VacuumPwr,65,,
VacuumPwrEco,65,,
Mattb83
Postby fmulders » February 15th, 2019, 2:20 am
As we do not know what the QAstate means I would advise you to ask Neato support via the live chat function on there support site.
(I can imagine that the robot has been send to support before and if they can not fix it they mark the serial number and set the QA state to "INVALID" This prevents support to look at it more than ones if the robot is send in again by a person who bought the defect robot.)
fmulders
Postby HiTec » February 15th, 2019, 5:30 pm
It also might be a robots own failed self test for hw/sw. I think QA_State comes from "Quality of Assurance State".
HiTec
Postby Mattb83 » February 16th, 2019, 3:39 am
I hope it isn’t that Neato have already tried to repair it.... as it’s on it’s way to their repair shop now!!! But it’s a possibility that they put a “stamp” on the software I suppose. I phoned Neato and they said they’ll make a exception and try to fix it under warranty (even though it’s run out).... hopefully find out soon.
Mattb83
Postby CarolineHardacre » February 18th, 2019, 8:33 am
replace your battery with the new one's some times batteries cycles got disturb and these error occurs.
CarolineHardacre
Users browsing this forum: drunkpenguin, Ionic, jdong, johnnyh, kosmoi, Mattb83, Miles267, RockinRay, someoneclever, teokakav, vic7767 and 388 guests
