Lidar state turns all red if D85 bumps into wall
Postby daniellee0412 » February 17th, 2019, 3:35 am
Hi everyone - newbie here, reading up on all the great threads on this forum :)
I have a D85, worked well for about a year, but recently when cleaning, after about 30 min, it'll stop with error 400x, and even if I retry, it'll stop over and over with a 400x error every time.I suspected a battery problem and replaced with a non-OEM battery, but I'm still seeing the same issue. Since this always occurs after running about 30 min, I suspected a low voltage problem and ran the Neato until I hit the 4000 error, than connected with NeatoControl and turned Vacuum/Lidar/Brush on, but FuelPercent>50 and BatteryVoltage stays at 12.2-12.4V. The BatteryCurrent jumps between -1000mA and -3000mA, I'm not sure if the wide range is normal.
While running the vacuum and lidar, the lidar scan looks good (see screenshot below), but if I hit the front corner of my neato with my fist, similar to if it's bumping into a wall, then the scan goes blank and the lidar state changes to all red. Turning the lidar off and back on doesn't help, but if I disconnect/reconnect NeatoControl and turn the lidar back on, then everything is back to normal. Could this cause the 4000x error during cleaning? Any ideas on how to fix this? Thanks!!
____ Discrete: ____=
SNSR_DC_JACK_IS_IN=False
SNSR_DUSTBIN_IS_IN=False
SNSR_LEFT_WHEEL_EXTENDED=False
SNSR_RIGHT_WHEEL_EXTENDED=False
LSIDEBIT=False
LFRONTBIT=False
LLDSBIT=False
RSIDEBIT=False
RFRONTBIT=False
RLDSBIT=False
____ Analog: ____=
BatteryVoltage=mV=12284
BatteryCurrent=mA=-1199
BatteryTemperature=mC=24070
ExternalVoltage=mV=788
AccelerometerX=mG=150
AccelerometerY=mG=23
AccelerometerZ=mG=992
VacuumCurrent=mA=336
SideBrushCurrent=mA=0
MagSensorLeft=VAL=0
MagSensorRight=VAL=0
WallSensor=mm=97
DropSensorLeft=mm=0
DropSensorRight=mm=0
____ Buttons: ____=
BTN_SOFT_KEY=False
BTN_SCROLL_UP=False
BTN_START=False
BTN_BACK=False
BTN_SCROLL_DOWN=False
BTN_SPOT=False
____ Charger: ____=
FuelPercent=60
BatteryOverTemp=0
ChargingActive=0
ChargingEnabled=0
ConfidentOnFuel=0
OnReservedFuel=0
EmptyFuel=0
BatteryFailure=0
ExtPwrPresent=0
ThermistorPresent=1
BattTempCAvg=24
VBattV=12.30
VExtV=0.78
Charger_mAH=0
Discharge_mAH=2951
daniellee0412
Users browsing this forum: ASTMedic, Ionic, jdong, Metalworker, vic7767 and 199 guests
