Kobold VR200 Problem and Neato Control. Now Correct Report
Postby Legolas84 » March 17th, 2019, 10:48 am
I have a kobold Vr200 (with last firmware) that has become stupid recently. Avoid obstacles that do not exist. It often goes in reverse for no reason.
I discovered the neato control and I use it on my kobold.
I test Lidar.
I put the robot in a box and this is the result:
In the first image the sides of the box are correctly detected, i think....
however in the second image there are red areas. According to the program are errors... Why do errors occur?
Are there any other tests i can do?
Kobold has other sensors below and to the side, and some on the bumper....
Thanks for help....
Legolas84
Re: Kobold VR200 Problem and Neato Control. Now Correct Repo
Postby HiTec » March 17th, 2019, 4:45 pm
Box is not a correct testing enviroment (too small). You should raise the robot so there is no obstacles for its vision and let it scan a room. 4x4m room would be perfect.
And you should test and check bumper sensors.
HiTec
Postby Lewiy » March 18th, 2019, 1:12 am
The lidar lid supports draws 10 stable shadows in the form of narrow sectors on a circular panaram. On XV series they look like in the picture below(in fact the same as your diagram):
The behavior you are describing is most likely due to false switching-on of drop sensors, magnetic sensors or bumper contact sensors.
Lewiy
Postby stivi83it » March 18th, 2019, 10:01 pm
plug it in to Neato Control again and see what the two magnetic sensors do. 0 Does not mean closed, 1 means closed, and 2 means error. The error is usually displayed 3-5 minutes after switching on.
stivi83it
Users browsing this forum: BrettS, cdogstu99, instrukcije, jdong, johnnyh, Metalworker, ps0001 and 377 guests
