Firmware 4.4.1-113
Firmware 4.4.1-113
Postby susantx3 » June 23rd, 2019, 1:05 pm
You now have the ability to turn off Robot sounds
susantx3
Re: Firmware 4.4.1-113
Postby voicegy » June 23rd, 2019, 2:16 pm
For what it's worth...
https://support.vorwerk.com/hc/de/artic ... s-ist-neu-
Description (translated from German):
The Kobold VR300 (Software Version 4.4.1.) Update brings the following improvements to your robotic vacuum cleaner:
With this version of the Kobold VR300 software it is possible to use the robot sounds in combination with the Kobold Robot App version 2.0.0. and switch off again.
This software also aims to fix listed bugs and improve usability:
Bug fixes that caused Kobold VR300 to skip areas or whole rooms in certain cases
Better recognition of the stored floor plan
Restart support for 5GHz Wi-Fi networks
A revised firmware
Various security improvements
(*NOTE*) The D7 is the only model in the Neato lineup that can connect to 5GHz WiFi
voicegy
Postby fmulders » June 28th, 2019, 1:15 am
Updated my D3.
No issues this time, update went smoothly.
Indeed you can toggle the sounds on/off, but why? I see that with the new version of the app, I can now also select "gentle navigation" with the spot clean mode.
But they still did not fix the issue that you cannot schedule a run with "eco" mode. (it will not stick and revert to "Turbo")
fmulders
Postby JEfromCanada » June 28th, 2019, 4:45 pm
fmulders wrote:Indeed you can toggle the sounds on/off, but why?
Maybe for those who run the bot while sleeping, and don't want to be disturbed by error beeps during the night?
Postby fmulders » June 29th, 2019, 3:46 am
Yes, but after startup beeps the volume is going up.
If you would wake from those beeps then you are definitely going to hear the rest of the operation. But for error beeps they got a point. Those can be consistent thru the night...
I noticed that there is a lot more information in the app when starting a cleaning run. It will now show you which floorplan is recognized. And indeed it is less picky. I could test this because at startup it has a view of two large chairs. If I slightly changed the position of those, it would not recognize the floorplan.
With this firmware I can move one of those around and it still recognize the correct floorplan!
fmulders
Users browsing this forum: BrettS, im1kissfan, jdong, KeldBroe, leonicholson, vic7767 and 438 guests
