neato D6: unable to fix "Dust me off" message
serbring
Post by serbring »
Hi all,
I have a Neato D6 (it is quite dated but so far it worked fine) which provides me the message "dust me off". I tried to clean the sensors as suggested in Neato's FAQ but the message is still there. When I press a button for cleaning, the robot starts the cleaning procedure but it stops after around a minute. What else should I do?
Thanks for your help.
CodaCM
Re: neato D6: unable to fix "Dust me off" message
Post by CodaCM »
serbring wrote:Hi all,
Have you tried cleaning the actual LIDAR sensor? Spinny disk under the part that sticks out the top. Try to use some Q-Tips and get in the LASR out and LASER in holes. If that does not work it’s something to do with an internal factor or Software issue. Hope this helps.
serbring
Post by serbring »
I already tried with a dry q-tip. Maybe, I should try with a little amount of detergent...
