Braava Jet off-label
Postby bs03 » July 4th, 2016, 9:27 pm
I got a Braava Jet.
I have a sensitivity to artificial scents.
I can only use the disposable pads in nice weather when all the windows are open.
I got washable pads. No scent is good but no cleaner/disinfectant is bad.
So my current thinking is that I either use something I use in my large Scooba in the Braava Jet, or I spray the floor with a cleaner and let the Braava "clean" it up.
Has anyone tried anything besides water?
Thanks for listening.
bs03
Re: Braava Jet off-label
Postby Frueds » July 26th, 2016, 2:19 am
Hi
I got the Braava Jet 240. The washable microfiber cloth is what I use. I spray the floors in a light fashion of the cleaning solution of my choice. It works wonders.
Frueds
Postby bs03 » October 19th, 2016, 12:59 am
Thanks. I have been pre-spraying the floor like you suggested. It only takes a second and seems to work well.
I'm sorry for not posting sooner.
bs03
Postby namuramc » January 25th, 2017, 1:05 pm
Hi guys, first post here and just got my Braava Jet. I was just wondering if the stuff for the Scooba 450 i.e the iRobot hard floor cleaner would be potentially safe for use on it? Was thinking to put a drop into the device before sending it off :D
Thanks in advance for your thoughts! :)
namuramc
Postby Atena » February 26th, 2017, 8:20 am
Frueds wrote:Hi
Hi
I have a Braava Jet 240 and I bought the washable microfiber cloth but I'm using only with water because I don't know which cleaning solution it's safe to use. I use the braava on hardwood floors and tile floors.
Which cleaning solution do you use?
Thanks in advance. :wink:
Atena
Postby bs03 » February 26th, 2017, 11:48 am
I have been using Frueds' suggestion of spraying the floor and then running the Braava with water in it. I have found I can use most cleaners this way.
I often use diluted vinegar around my house. I use this on all of my floors, even my wood floors from 1960. This is my routine option.
For periodic or tougher cleaning, I dilute pourable Lysol or Mr.Clean and put it in a spray bottle for my solid floors. I'll use Murphy's Oil Soap in a spray bottle for my wood floors.
I tried using Method bathroom spray but it left my floor sticky. I did not try diluting it.
I would say anything that you can use with a mop should work best.
bs03
Postby Atena » February 26th, 2017, 6:34 pm
bs03 wrote:I have been using Frueds' suggestion of spraying the floor and then running the Braava with water in it. I have found I can use most cleaners this way.
Thank you for your help! :) Reading what you said I came to the same conclusion: we can use anything that can be used with a mop. I'll browse the cleaning products available in my country.
Thanks :wink:
Atena
Users browsing this forum: 911medic, FlyingPolarBear, im1kissfan, KeldBroe, leonicholson, Miles267, someoneclever, sshephard, teokakav, vic7767 and 369 guests
